![]() "Toņo" wrote I have always considered mountain flying to be flying *in* the mountains and the things that concern a mountain pilot to be at or below the peaks. Is this incorrect? Yes. The waves extend way up past the peaks, and so do rotors. -- Jim in NC |
Morgans wrote:
"Toņo" wrote I have always considered mountain flying to be flying *in* the mountains and the things that concern a mountain pilot to be at or below the peaks. Is this incorrect? Yes. The waves extend way up past the peaks, and so do rotors. Not according to Sparky Imeson.... "...the rotor cloud will be downwind from the mountain range and extend anywhere from the earth's surface to up to mountain-top level". --p.63 of "Mountain Flying" by Sparky Imeson In 15 years of mountain flying I have never encountered a rotor above a mountain peak. Turbulence, yes...but *rotors*, no. I have encountered waves and even flown in them. Sometimes the waves extend hundreds of miles downwind of a range! Waves are not at all dangerous to fly in! In fact, gliders often take advantage of their superior lift and laminar air. I have often paralleled a mountain range to take advantage of them. Antonio |
![]() "Toņo" wrote Not according to Sparky Imeson.... "...the rotor cloud will be downwind from the mountain range and extend anywhere from the earth's surface to up to mountain-top level". --p.63 of "Mountain Flying" by Sparky Imeson Antonio There is some disagreement with this, and here is a clip: Normally the rotor clouds is centered beneath the lenticular cloud. Most often it extends anywhere from ground level to mountaintop level, but is frequently observed up to 35,000 feet. Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level. http://www.mountainflying.com/mountain_wave2.htm My point is, just because you clear the ridge, there are still dangers that can ruin your day, if the winds are right. Further down in the article, this author talks about rotors that do not have a visible cloud. If the wind is blowing strong, close to perpendicular to the ridge, best wait until early the next day, and see if the winds are calmed down. Hey, I just read, and remember. I have no idea if what everyone says is true. I would rather be safe, than sorry. YMMV -- Jim in NC |
Morgans wrote:
"Toņo" wrote Not according to Sparky Imeson.... "...the rotor cloud will be downwind from the mountain range and extend anywhere from the earth's surface to up to mountain-top level". --p.63 of "Mountain Flying" by Sparky Imeson Antonio There is some disagreement with this, and here is a clip: Normally the rotor clouds is centered beneath the lenticular cloud. Most often it extends anywhere from ground level to mountaintop level, but is frequently observed up to 35,000 feet. Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level. Well? Your last sentence says it..."Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level." I see no "disagreement" about it. My point is, just because you clear the ridge, there are still dangers that can ruin your day,snip I agree and never stated otherwise. However, the OP was wondering whether he should take a "mountain flying" course in order to make a cross-country trip at altitudes of 16-19,000 ft. My contention was that this was not *mountain flying* per se and that he was wasting his time thinking that a mountain flying course would in any way prepare him for the trip. The topic is not "are there dangers at high altitudes" as some here seem to be trying to make it; it is: "would one benefit by a mountain flying course if one were flying at high altitudes?" At least, that's how I read it. Thanks for the great link! Antonio |
![]() "Morgans" wrote in message news ![]() There is some disagreement with this, and here is a clip: Normally the rotor clouds is centered beneath the lenticular cloud. Most often it extends anywhere from ground level to mountaintop level, but is frequently observed up to 35,000 feet. Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level. http://www.mountainflying.com/mountain_wave2.htm My point is, just because you clear the ridge, there are still dangers that can ruin your day, if the winds are right. Further down in the article, this author talks about rotors that do not have a visible cloud. If the wind is blowing strong, close to perpendicular to the ridge, best wait until early the next day, and see if the winds are calmed down. Hey, I just read, and remember. I have no idea if what everyone says is true. I would rather be safe, than sorry. YMMV -- Jim in NC Hmmmm, I've been through the rotor a few times -- while yanking and banking on the end of a 200' length of towrope behind a tow-plane. The first time is the worst. After that you remember to breathe and you don't suck quite as hard on the seat cushion. When you're headed for the primary wave developed on the east slope of the Sierra, the rotor is unavoidable. Some folks, with more skill than I possess, ride thermals up into the secondary wave and, when high enough slide over to the primary. I guess I never thought of the rotor as destructive. Maybe I shouldn't do that again. |
![]() "Casey Wilson" N2310D @ gmail.com wrote in message news:iqbbe.6406$Nc.4745@trnddc08... "Morgans" wrote in message news ![]() There is some disagreement with this, and here is a clip: Normally the rotor clouds is centered beneath the lenticular cloud. Most often it extends anywhere from ground level to mountaintop level, but is frequently observed up to 35,000 feet. Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level. http://www.mountainflying.com/mountain_wave2.htm My point is, just because you clear the ridge, there are still dangers that can ruin your day, if the winds are right. Further down in the article, this author talks about rotors that do not have a visible cloud. If the wind is blowing strong, close to perpendicular to the ridge, best wait until early the next day, and see if the winds are calmed down. Hey, I just read, and remember. I have no idea if what everyone says is true. I would rather be safe, than sorry. YMMV -- Jim in NC Hmmmm, I've been through the rotor a few times -- while yanking and banking on the end of a 200' length of towrope behind a tow-plane. The first time is the worst. After that you remember to breathe and you don't suck quite as hard on the seat cushion. When you're headed for the primary wave developed on the east slope of the Sierra, the rotor is unavoidable. Some folks, with more skill than I possess, ride thermals up into the secondary wave and, when high enough slide over to the primary. I guess I never thought of the rotor as destructive. Maybe I shouldn't do that again. It can be fatal but that is an extreme case with winds at ridgetop level over 100kts. There is a chapter in Exploring the Monster describing a flight into a rotor by Mt. Tom which is slightly north of Bishop where the glider broke up and the pilots were subject to +16G and -20G. I have actually "heard" rotors hissing and roaring near Genoa, NV with winds over 100kts at ridge level but calm in the valley because of a strong inversion so it happens but only in extreme weather. It was a textbook day for a record attempt but nobody flew out of Minden that day. In any case, gliders are much better suited to thiese conditions than GA airplanes. Mike MU-2 |
![]() "Casey Wilson" N2310D @ gmail.com wrote in message news:iqbbe.6406$Nc.4745@trnddc08... "Morgans" wrote in message news ![]() There is some disagreement with this, and here is a clip: Normally the rotor clouds is centered beneath the lenticular cloud. Most often it extends anywhere from ground level to mountaintop level, but is frequently observed up to 35,000 feet. Destructive turbulence from the rotor rarely exists more than 2,000-3,000 feet above mountaintop level. http://www.mountainflying.com/mountain_wave2.htm My point is, just because you clear the ridge, there are still dangers that can ruin your day, if the winds are right. Further down in the article, this author talks about rotors that do not have a visible cloud. If the wind is blowing strong, close to perpendicular to the ridge, best wait until early the next day, and see if the winds are calmed down. Hey, I just read, and remember. I have no idea if what everyone says is true. I would rather be safe, than sorry. YMMV -- Jim in NC Hmmmm, I've been through the rotor a few times -- while yanking and banking on the end of a 200' length of towrope behind a tow-plane. The first time is the worst. After that you remember to breathe and you don't suck quite as hard on the seat cushion. When you're headed for the primary wave developed on the east slope of the Sierra, the rotor is unavoidable. Some folks, with more skill than I possess, ride thermals up into the secondary wave and, when high enough slide over to the primary. I guess I never thought of the rotor as destructive. Maybe I shouldn't do that again. If you are talking about flying at Minden, you can often get into the primary wave without going throught the rotor by flying west. You will be in low level turbulence but it won't be too bad. When you are so close to the mountains that you say: "no way I'm going any closer" and start to turn away (about a mile) you will often start to pick up lift at 5500-6000' stay close to the mountains and you can get over the rotor by keeping west of it. This only works when the wind is really screaming, (80kts+ at the ridges) and the rotor cloud is almost over the airport. I once climbed to FL290 in the MU-2 in perhaps four minutes. The IVSI goes to 6000fpm and it was pegged the whole time. It is also worth knowing that both instrument approaches and the instrument departure proceedure go through the rotor when wave conditions are strong. Mike MU-2 |
Antionio,
Sorry to throw you off, but the "Mountain Flying" book was written 35-years ago. I've learned something in that time and have observed rotors along the Front Range between 25,000- and 30,000-feet MSL. Usually the destructive turbulence associated with the rotor does not extend more than a 1,000 feet or so above the ridge line. Sparky |
Rotors do not extend much above the ridgetops. The waves themselves are
smooth until reaching the tropopause except the extreme case of breaking waves. Mike MU-2 "Morgans" wrote in message ... "Toņo" wrote I have always considered mountain flying to be flying *in* the mountains and the things that concern a mountain pilot to be at or below the peaks. Is this incorrect? Yes. The waves extend way up past the peaks, and so do rotors. -- Jim in NC |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
TSA rule 49 CFR Part 1552 (or its misinterpretation) is already preventing people from flying (even renters) (long) | Bay Aviator | Piloting | 15 | October 21st 04 10:29 PM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
