Best tug for a 3000lb SEP?
Old April 25th 05, 12:27 PM
Ron Rosenfeld
On Sun, 24 Apr 2005 15:06:51 -0700, "Matt Barrow"
Pushing can be done with the tractor because it has a nice (read strong) two
speed reverse gear (and three forward). I use it to get the bird back into
the hanger as there is about a 2" lip to across on the foundation slab.
Our tractor has multiple slow speeds, too. I think there are about ten or
twelve forward and four reverse.
But my problem has to do with the joints at the towbar-tractor and
towbar-a/c. Once I get a little off, I can't seem to (easily) get things
straightened out again. And the Mooney has fairly narrow nosewheel turning
limits (+/-15° if I recall correctly).
I'm sure with practice I could do better. But now with the Nose Dragger
Dragger I don't use the tractor, unless I have to tow long distances (in
which case I pull and don't push).
Old April 25th 05, 03:14 PM
Matt Barrow
"Ron Rosenfeld" wrote in message
two
into
turning
I think that's more than the Bonanza.
Hmmm... I always found it was like backing a trailer. If things get out of
whack (as opposed to in whack) just go forward and start over. I try to
avoid counting on the nosewheel being able to make up for my misalignment.
One thing is to avoid trying to cut some sharp angles. Also, having enough
room is helpful; if our taxiway lane was more cramped, I'd probably find it
a lot more traumatic.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old April 26th 05, 02:28 AM
Ron Rosenfeld
On Mon, 25 Apr 2005 07:14:02 -0700, "Matt Barrow"
Well, I don't have any experience backing a trailer. So that's probably
why I spent almost equal times in forward as in reverse :-))
Fortunately, for me, I have another solution , now.
Old April 26th 05, 03:35 PM
Matt Barrow
of
Just remember that the trailer (or whatever) goes in the direction you turn
the steering wheel. :~)
Matt
Matthew W. Barrow
Montrose, CO
Old April 27th 05, 12:02 PM
Ron Rosenfeld
On Tue, 26 Apr 2005 07:35:35 -0700, "Matt Barrow"
I do. I still can't get the nack of it. Lots of PIO here :-(
Best tug for a 3000lb SEP? Newps Owning 0 April 22nd 05 08:35 PM
