The difference is that a VOR outage affects only that VOR, so a workaround
exists using other VORs and the same equipment in the aircraft. A GPS outage affects the system, at least within an area, so there are no alternative stations to tune to for a work-around. C J Campbell wrote: I might point out that VORs are also inoperative at certain time in certain regions. The Mc Chord VOR has not worked in over a year, despite it being an important airway intersection. So what are you suggesting we use for backup navigation systems for the VOR? -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Ray Andraka wrote:
The difference is that a VOR outage affects only that VOR, so a workaround exists using other VORs and the same equipment in the aircraft. A GPS outage affects the system, at least within an area, so there are no alternative stations to tune to for a work-around. C J Campbell wrote: Bull****. GPS also works using multiple satellites and multiple frequencies. If you are going to propose that the entire frequency band for GPS be jammed or otherwise corrupted, then the same thing would work across the entire VOR band as well. -- For most men, true happiness can only be achieved with a woman. Also for most men, true happiness can only be achieved without a woman. Sharp minds have noted that these two rules tend to conflict..... |
![]() "Scott Moore" wrote in message ... Bull****. GPS also works using multiple satellites and multiple frequencies. If you are going to propose that the entire frequency band for GPS be jammed or otherwise corrupted, then the same thing would work across the entire VOR band as well. Umm, no. GPS, as far as aviation is currently concerned, operates on a single frequency called L1 (1.57542 GHz). Even if you were to use L2 as well, they aren't redundant. The reason for the second frequency (civil use) is to allow correction to the ionospheric propagation delay. In theory, the spread spectrum nature makes it difficult to jam effetively. Of course, that's with an ideal reciever. You can knock out a lot of receivers by just throwing enough RF at them. |
Nope, GPS for aviation is essentially one frequency with code modulation. The
receiver picks out the different satellites by correlating the code sequence against the received signal. The code sequences are orthagonal, which means they are enough different that you only get a strong correlation peak for the one satellite that matches the code you are correlating against. The long code sequences provide a very high processing gain, so the signals can be buried in a good deal of noise, however it is relatively easy to jam the entire system with a strong transmittter on the carrier frequency. This is what RAIM is all about. It doesn't even have to be an intentional jammer: intermodulation from TV transmitters in close proximity has caused local outages, for example. It would be much harder to jam the entire VOR band because the VOR signals are transmitted at much higher power (3 orders of magnitude), and the VOR band covers a wide frequency band relative to the frequency of the center of the band. Scott Moore wrote: C J Campbell wrote: Bull****. GPS also works using multiple satellites and multiple frequencies. If you are going to propose that the entire frequency band for GPS be jammed or otherwise corrupted, then the same thing would work across the entire VOR band as well. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Please do not mis-attribute others' remarks to me. I did not post the quoted
material. "Ray Andraka" wrote in message ... | Nope, GPS for aviation is essentially one frequency with code modulation. The | receiver picks out the different satellites by correlating the code sequence | against the received signal. The code sequences are orthagonal, which means they | are enough different that you only get a strong correlation peak for the one | satellite that matches the code you are correlating against. The long code | sequences provide a very high processing gain, so the signals can be buried in a | good deal of noise, however it is relatively easy to jam the entire system with a | strong transmittter on the carrier frequency. This is what RAIM is all about. It | doesn't even have to be an intentional jammer: intermodulation from TV transmitters | in close proximity has caused local outages, for example. | | It would be much harder to jam the entire VOR band because the VOR signals are | transmitted at much higher power (3 orders of magnitude), and the VOR band covers a | wide frequency band relative to the frequency of the center of the band. | | Scott Moore wrote: | | C J Campbell wrote: | | Bull****. GPS also works using multiple satellites and multiple frequencies. | If you are going to propose that the entire frequency band for GPS be jammed | or otherwise corrupted, then the same thing would work across the entire | VOR band as well. | | -- | --Ray Andraka, P.E. | President, the Andraka Consulting Group, Inc. | 401/884-7930 Fax 401/884-7950 | http://www.andraka.com | | "They that give up essential liberty to obtain a little | temporary safety deserve neither liberty nor safety." | -Benjamin Franklin, 1759 | | |
Engine update, good and bad news | nauga | Home Built | 3 | June 25th 04 06:26 PM |
Sport Pilot Leaves DOT for OMB, Latest News | Fitzair4 | Home Built | 3 | December 25th 03 02:49 AM |
Test..sorry, please ignore, just trying a new isp, news server, and newsreader. | Doug Sowder | Aerobatics | 0 | November 9th 03 06:04 PM |
It's all about the credibility you don't have, ChuckZZZ | Juan.Jimenez | Home Built | 8 | November 4th 03 01:03 PM |
News server problems on just this group | Chris W | Home Built | 9 | August 9th 03 02:32 AM |
