Big News -- WAAS GPS is Operational for IFR
Old July 16th 03, 06:32 PM
Ray Andraka
Nope, GPS for aviation is essentially one frequency with code modulation. The
receiver picks out the different satellites by correlating the code sequence
against the received signal. The code sequences are orthagonal, which means they
are enough different that you only get a strong correlation peak for the one
satellite that matches the code you are correlating against. The long code
sequences provide a very high processing gain, so the signals can be buried in a
good deal of noise, however it is relatively easy to jam the entire system with a
strong transmittter on the carrier frequency. This is what RAIM is all about. It
doesn't even have to be an intentional jammer: intermodulation from TV transmitters
in close proximity has caused local outages, for example.
It would be much harder to jam the entire VOR band because the VOR signals are
transmitted at much higher power (3 orders of magnitude), and the VOR band covers a
wide frequency band relative to the frequency of the center of the band.
Scott Moore wrote:
C J Campbell wrote:
Bull****. GPS also works using multiple satellites and multiple frequencies.
If you are going to propose that the entire frequency band for GPS be jammed
or otherwise corrupted, then the same thing would work across the entire
VOR band as well.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old July 17th 03, 06:22 AM
C J Campbell
Please do not mis-attribute others' remarks to me. I did not post the quoted
material.
"Ray Andraka" wrote in message
The
sequence
means they
one
code
buried in a
with a
about. It
transmitters
signals are
covers a
| Scott Moore wrote:
frequencies.
jammed
| VOR band as well.
| --Ray Andraka, P.E.
| email
Engine update, good and bad news nauga Home Built 3 June 25th 04 06:26 PM
Sport Pilot Leaves DOT for OMB, Latest News Fitzair4 Home Built 3 December 25th 03 02:49 AM
Test..sorry, please ignore, just trying a new isp, news server, and newsreader. Doug Sowder Aerobatics 0 November 9th 03 06:04 PM
It's all about the credibility you don't have, ChuckZZZ Juan.Jimenez Home Built 8 November 4th 03 01:03 PM
News server problems on just this group Chris W Home Built 9 August 9th 03 02:32 AM
