Losing the rudder is one thing, losing the vertical stab is another thing
entirely... Boeing addressed the 737 problem by redesigning the yaw damper system and retrofitting it in the field, so bringing this up to defend the flaw in the A300 is a non-sequiter argument. The fact remains, the A300 has a design flaw of some kind that needs to be fixed. If Airbus wants to try to sweep it under the rug, they are just going to wind of killing more people. They need to proactively investigate the design and determine what is wrong, the come up with a real fix. Tapping on the tail doesn't cut it... Dean "Stefan" wrote in message ... Jay Honeck wrote: I wonder if they've addressed the rudder pedal boost, which was apparently much more sensitive than necessary? It was necessary because the rudder must have enough authority to keep the plane straight if flown on only two engines on the same side. The investigation of the accident (to which you apparently refer) clearly states that most other airliners (747 comes to mind) would also have lost its rudder. But I would think they have enhanced the software to limit rudder usage, although I don't know. I don't know, either, whether the involved airline has enhanced their pilot training. Do you really want to restart this discussion? Stefan |
On Thu, 28 Apr 2005 at 14:16:28 in message
, Dean Wilkinson wrote: Boeing addressed the 737 problem by redesigning the yaw damper system and retrofitting it in the field, so bringing this up to defend the flaw in the A300 is a non-sequiter argument. The fact remains, the A300 has a design flaw of some kind that needs to be fixed. If Airbus wants to try to sweep it under the rug, they are just going to wind of killing more people. They need to proactively investigate the design and determine what is wrong, the come up with a real fix. Tapping on the tail doesn't cut it... Can you give a reference that shows where the 'flaw' in the A300 design is? There are three principle factors in an in-flight structural failure. 1. The design requirements. These are laid down by aviation authorities, not designers. If these are wrong or insufficient then they need revising for all aircraft of that class. 2. The designers who must meet those requirements and convince the aviation authority that design and testing shows that these requirements are met. 3. Those who fly and operate the aircraft and must see that all maintenance training and operation are within the design limits. If there is a flaw in which category is it? Over the years there have been crashes in which all of the above have been in error. You cannot design, build and operate an aircraft which is proof against _all_ errors or mistakes whether accidental or deliberate. -- David CL Francis |
Laser beams being aimed at airliners? | Corky Scott | Piloting | 101 | January 22nd 05 08:55 AM |
PIREPS / airliners | [email protected] | Piloting | 10 | January 21st 05 11:15 PM |
2 civilian airliners down south of Moscow | Pete | Military Aviation | 64 | September 11th 04 04:16 PM |
Another boring post... | G. Burkhart | Piloting | 10 | June 5th 04 07:06 PM |
121.5 & Airliners | Nolaminar | Soaring | 19 | November 20th 03 07:35 AM |
