"Out of fuel, out of hope: 'Help, I'm in the water'"
Old April 29th 05, 01:00 PM
Jon Kraus
I wonder what would have happened if he would have called 30 minutes
before running out of gas and had the Coast Guard giving him "Flight
Following" Maybe they could have got there before the plane sank. I
don't even know if that was a possibility. Just a thought.
Jon Kraus
PP-ASEL-IA
'79 Mooney 201
Steven P. McNicoll wrote:
"Chris" wrote in message
Its all speculation, the poor planning was one issue, poor execution of
his way out of the problem was the other.
Poor planning is a certainty, there was no proper execution out of this
problem.
Old April 29th 05, 01:04 PM
Peter R.
Following"
That would assume he *knew* he had only 30 minutes of fuel left.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old April 29th 05, 02:21 PM
Nathan Young
On Fri, 29 Apr 2005 08:04:40 -0400, "Peter R."
Following"
If you listen to the ATC tapes (link posted elsewhere in this thread),
he knew he was low on fuel. He indicates that he had run one tank
dry, and only had 3-6 gallons left in the other tank.
Sure it's armchair QB'ing, but at this point, he should have been
relaying exact position and asking for the USCG chopper/ships to be
rolling.
-Nathan
Old April 29th 05, 03:42 PM
Steven P. McNicoll
"Nathan Young" wrote in message
Do you know what his position was when he indicated that?
rolling.
That assumes he was able to determine his exact position. What navigational
capabilities did he have aboard?
Old April 29th 05, 02:00 PM
Steven P. McNicoll
"Jon Kraus" wrote in message
Following" Maybe they could have got there before the plane sank. I don't
I don't know what his route was, but thirty minutes earlier he was probably
over land east of the lake.
Old April 30th 05, 02:41 AM
George Patterson
No, he would have been well offshore. The lake is about 80 nm wide at that
point, and that's if you're traveling straight across. The news said he would
have been swimming against a 3 knot headwind, so he was fighting higher winds at
altitude. Unless his Archer could true at least 175 knots, he was over water 30
minutes earlier.
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old April 30th 05, 03:13 AM
Steven P. McNicoll
"George Patterson" wrote in message
news:0nBce.505$yd1.85@trndny01...
would have been swimming against a 3 knot headwind, so he was fighting
higher winds at altitude. Unless his Archer could true at least 175 knots,
he was over water 30 minutes earlier.
You might want to run that problem again. On a direct route from Hamilton
NY to Watertown WI the lake is about 68 nm wide, not 80. According to the
NTSB he went down six miles east of the lakeshore, so the dry tanks point
was a few miles further east and dependant on altitude. He probably crossed
about 55-60 miles of the lake. The book cruise speed of the Archer II is
139 ktas but he was probably achieving something a bit less than that. The
winds at altitude are also unknown. He may have been over water 30 minutes
prior to engine stoppage, but he was certainly not well offshore.
Old April 29th 05, 02:10 PM
john smith
Lake Watch Reporting Progam is available through Flight Service.
Contact FSS prior to going feet wet.
Call FSS every 10 minutes and report as necessary (High and Dry, or Mayday!)
Cancel Lake Watch when feet dry.
With the exception of Western Lake Erie where I can island hop within
gliding distance, I will not cross open water without using this service
or or talking to ATC.
Old April 29th 05, 03:39 PM
Steven P. McNicoll
"john smith" wrote in message
Mayday!)
It's actually called Lake Reporting Service, one of the Hazardous Area
Reporting Services provided by FSS. The descriptions of them are cleverly
hidden in the AIM in the Air Traffic Control chapter.
I suppose it's better than nothing, but radar coverage over southern Lake
Michigan is good and flight following is definitely superior.
Old April 30th 05, 05:07 AM
Dave Stadt
Mayday!)
In this case it would not have helped. Unfortunately, under the
circumstances, he was dead when the engine quit.
Most experienced CFI runs out of gas Robert M. Gary Piloting 54 November 19th 04 01:24 AM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 02:21 AM
Sheepskin seat covers save life. Kevin Owning 21 November 28th 03 10:00 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
