Radio license required?
Old July 17th 03, 09:58 PM
Ron Natalie
"gross_arrow" wrote in message om...
"Ron Natalie" wrote in message om...
"Marty Ross" wrote in message ...
Where are these regs (required documents onboard) anyways?
As I said, I couldn't (quickly) find them in the FAR/AIM.
Airworthiness certificate: 91.203(a)(1)
Registration: 91.203(a)(2)
Operating Limitations: 91.9
Weight and Balance: Not specifically mentioned by the FAR. It is usually either
specifically required by the type certificate or it's part of the flight manual (operating
limitations).
i'd like to advance the argument that the weight & balance are
operating limitations, and hence covered under 91.9. though there
is not a specific requirement for the documents, it would be difficult
to demonstrate that you were operating within the limitations without
those documents.
I believe that is what I said. Thats why ARROW is a sucky acronym (even before
the second R became moot). There's no specific, seperate callout for the W&B.
If you have an AFM, it most likely has to be up to date with all kinds of things including
the W&B and that won't be a seperate thing. For my plane, the type certificate
specifically says I gotta have two things in the plane:
1. A book called Operating Limitations.
2. An equipment list.
I've also got some flight manual supplements to a non-existant flight manual that
came with some STC's.
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
Jim Weir or other qualified persons: a tangent on the 2 radio 1 antennathread Dave S Home Built 12 June 23rd 04 01:03 AM
Radio squeal Gerrie Home Built 4 August 5th 03 09:28 PM
Ham Radio In The Airplane Doug Carter Home Built 24 July 8th 03 03:30 AM
