![]() "Mortimer Schnerd, RN" wrote in message .com... Matt Barrow wrote: Here's just a few: 1) Poor fuel planning and continuing on with low fuel from Michigan side. 2) Water crossing 3) No floatation devices If he had pants on, he had floatation gear. Get someone to show you how to knot the legs, then inflate the pants by swinging it over your head from above and behind you to in front of you in one swift movement. The trapped air will then hold you up for quite a while like water wings.... and they can always be reinflated ad nauseum. His biggest risk was hypothermia. If he'd only had a light.... I always carry a waterproof light with me in my car and when I fly. Always. He was an expert swimmer and it took the search boat how long to reach the area? In 32 degree water he would have lasted only 30 minutes at best; they would have found his corpse. As he was very lean, he might have had even less time. Has anyone ever seen a small inflatable raft (2-4 person) that would be small enough to carry onboard an aircraft? I figure it would keep you out of the water. |
On Fri, 29 Apr 2005 08:01:08 -0700, "Matt Barrow"
wrote in :: In 32 degree water he would have lasted only 30 minutes at best If the water had been 32 degrees F (instead of 40), he could have walked to shore. :-) |
![]() "Larry Dighera" wrote in message ... If the water had been 32 degrees F (instead of 40), he could have walked to shore. :-) If the water had been 32 degrees F instead of 40 it would have been 8 degrees colder, but it still would have been liquid. |
On Fri, 29 Apr 2005 18:04:28 GMT, "Steven P. McNicoll"
wrote in . net:: If the water had been 32 degrees F instead of 40 it would have been 8 degrees colder, but it still would have been liquid. I thought it was fresh water, not salty. Or are you referring to the agitation from wind keeping it liquid? |
![]() "Larry Dighera" wrote in message ... I thought it was fresh water, not salty. It is. Were you under the impression that fresh water exists only as a solid at 32F? Or are you referring to the agitation from wind keeping it liquid? That's part of it. Another part of it is the way ice forms on lakes and how much ice it takes to support how much weight. |
On Fri, 29 Apr 2005 18:38:01 GMT, "Steven P. McNicoll"
wrote in et:: "Larry Dighera" wrote in message .. . I thought it was fresh water, not salty. It is. Were you under the impression that fresh water exists only as a solid at 32F? I am aware that super cooled water can remain in the liquid state a few degrees below 32F. Or are you referring to the agitation from wind keeping it liquid? That's part of it. Another part of it is the way ice forms on lakes and how much ice it takes to support how much weight. Right. My comment was more of a tongue-in-cheek correction than a lesson in physics. But I do appreciate your firsthand information. What really puzzles me is your complete lack of comment on my views of Ninja-1's decisions in the November 16, 2000 F-16/Cessna 172 MAC. Did someone contact you with a warning about participating in that discussion? Or is your reticence a result of your government employment or something else? |
![]() "Larry Dighera" wrote in message ... Right. My comment was more of a tongue-in-cheek correction than a lesson in physics. But I do appreciate your firsthand information. I don't think you're in a position to be teaching any physics! What really puzzles me is your complete lack of comment on my views of Ninja-1's decisions in the November 16, 2000 F-16/Cessna 172 MAC. Did someone contact you with a warning about participating in that discussion? Or is your reticence a result of your government employment or something else? I thought I made my position on that episode quite clear. |
![]() "Steven P. McNicoll" wrote If the water had been 32 degrees F instead of 40 it would have been 8 degrees colder, but it still would have been liquid. It is arguing nits, but I'll play the game you started. If the water of the lake was all indeed at 32 degrees, it would all be a giant ice cube. If it were all at 32.1 degrees, it would all be liquid. The wave action has nothing to do with it. In reality, lakes do not freeze because of wave action, because it keeps the deeper warmer water mixed with the water at the surface that is trying to get frozen because of the colder air. When the water just below the surface is cold enough that it can't keep the water at the surface warm enough, it starts to freeze. Water has the unusual property of getting less dense, when it gets to almost freezing. That is the only thing that keeps lakes from freezing solid, from the bottom up. Most things get more dense as they get colder, so the cold sinks to the bottom of the container, but not water. -- Jim in NC |
![]() "Morgans" wrote in message ... It is arguing nits, but I'll play the game you started. If the water of the lake was all indeed at 32 degrees, it would all be a giant ice cube. If it were all at 32.1 degrees, it would all be liquid. The wave action has nothing to do with it. So in other words, the physical state of water is a function of temperature alone? |
![]() "Steven P. McNicoll" wrote in message news ![]() "Morgans" wrote in message ... It is arguing nits, but I'll play the game you started. If the water of the lake was all indeed at 32 degrees, it would all be a giant ice cube. If it were all at 32.1 degrees, it would all be liquid. The wave action has nothing to do with it. So in other words, the physical state of water is a function of temperature alone? Zactly. Waves stir the water, and bring up the warmer water to the surface, if there is warm enough water down there to keep it from freezing. There is ultimate proof that waves are not enough, because some winters, the Great Lakes still freeze over. I'll bet there were waves, when it started to freeze. The air was cold enough to get the surface temperature down to 32.0, or lower. Period. Same principle with some boats at marinas that stay in the water all winter. They put an air bubble pump with the hose under the boat, to keep the water circulating. It works pretty well. -- Jim in NC |
Most experienced CFI runs out of gas | Robert M. Gary | Piloting | 54 | November 19th 04 01:24 AM |
Fuel dump switch in homebuilt | Jay | Home Built | 36 | December 5th 03 02:21 AM |
Sheepskin seat covers save life. | Kevin | Owning | 21 | November 28th 03 10:00 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
