#121
"Jon Kraus" wrote in message
... Amen brother... I don't believe in coincidences any more nor am I a religious zealot... I just KNOW that I am being cared for... :-) But encountering turbulence sometime during a long flight isn't even a "coincidence". It would be unusual for that *not* to occur. --Gary |
#122
Peter R. wrote:
So, who was caring for that 20 year-old who ditched in the lake? The ones that got him down: the pilot who was relaying his calls to ATC, the 911 operator who took his phone call after he ditched and lost aviation radio contact... He was calm and collected the entire time, I'd say he knew where he was going and they were already there with him... |
#123
In article , Dave Stadt wrote:
In this case it would not have helped. Unfortunately, under the circumstances, he was dead when the engine quit. Even if the lake hadn't been so cold, he would be pretty much stuffed. 3 foot waves don't sound a lot, but when you're swimming only your head is out. At night he could have had absolutely no idea which direction he should swim unless he could astronavigate (which I suspect he couldn't). There would be more chances of swimming in the wrong direction instead of the most direct route to the shore if there's nothing to guide you. The waves would have completely blocked his view of the land most of the time, especially as he'd probably go under each wave regardless of how strong a swimmer he was. Even in daylight it would be difficult enough, but at least then you could get an idea of which way to swim from the position of the sun assuming it wasn't overcast. The only thing he did right was not to panic, but unfortunately it didn't help. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#124
![]() "Jose" wrote in message ... I don't even get that in the Dakota. You sure that's not MPH? All my performance figures came from the 1976 Flying Annual & Buyers Guide, it gives a cruise speed at 75% power of 139 knots. I'm familiar with the Archer II, I know it won't go that fast. That's why I pointed out it was a book figure and that he was achieving a somewhat lower speed. |
#125
![]() "Morgans" wrote in message ... It is arguing nits, but I'll play the game you started. If the water of the lake was all indeed at 32 degrees, it would all be a giant ice cube. If it were all at 32.1 degrees, it would all be liquid. The wave action has nothing to do with it. So in other words, the physical state of water is a function of temperature alone? |
#126
In article , Jon Kraus wrote:
Musta been his time I guess... Just because he died doesn't mean he wasn't card for... Just my .02 The only person who ultimately directly cares for us when we are solo in an aircraft is ourselves. No one else. You are the captain of your own soul as well as your aircraft. You are the only person looking after yourself in that situation; remember that. If you expect some divine being to care for you, I think you're just looking for a grid reference. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#127
Morgans wrote:
Water has the unusual property of getting less dense, when it gets to almost freezing. That is the only thing that keeps lakes from freezing solid, from the bottom up. Most things get more dense as they get colder, so the cold sinks to the bottom of the container, but not water. No, that isn't the only thing. The ground stays warmer than the air during the winter, so water would still freeze from the top down even if the density didn't change during the phase change. Matt |
#128
![]() "Dylan Smith" wrote in message ... Even if the lake hadn't been so cold, he would be pretty much stuffed. 3 foot waves don't sound a lot, but when you're swimming only your head is out. At night he could have had absolutely no idea which direction he should swim unless he could astronavigate (which I suspect he couldn't). There would be more chances of swimming in the wrong direction instead of the most direct route to the shore if there's nothing to guide you. The waves would have completely blocked his view of the land most of the time, especially as he'd probably go under each wave regardless of how strong a swimmer he was. The lights of the city should be visible. |
#129
I'll play along even though my most harrowing aviation faux paux is
nothing compared to that of others. I was a brand new solo pilot in the practice area trying to run through all the maneuvers. My least favorite being the dreaded departure stall. "Oh well" I thought let's get this over with. I set up full throttle, point the nose up and started losing airspeed. As I got the stall speed I remember thinking "If I don't keep the ball centered I will have problems" and as soon as that thought was complete in my head it happened. The wing snapped over and my windscreen was full of the ground below. I remember thinking "so this is how I am going to die huh.." I was strangely calm and thinking clearly. I saw the airspeed in the yellow and heading up. I grabbed the throttle and pulled it to idle. The nose immediately "popped" up, I leveled the wings, gently brought the nose to the horizon and flew away. I told myself "well Jon that is enough practicing for one day" :-) and I went back to my home airport. The thing that was interesting was that there was no panic at all. If anything I was angry that I let myself get into this situation. I realize now that I was in a spiral dive and not a spin. To this day I still don't care for departure stalls. Jon Kraus PP-ASEL-IA '79 Mooney 201 Matt Barrow wrote: snip Along those line, anoyone got any good ghost stories? :~) Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO Matt Barrow wrote: "Jon Kraus" wrote in message ... Sounds like the grace of God to me... Well placed bit of turbulence my ass.... Somone was looking out for you... Maybe...but I was over the eastern slope of the Rockies, so turbulence is rather common that time of day. Even at 10,500 I was only about 2000 feet AGL when roused from my slumber. |
#130
In article et,
Steven P. McNicoll wrote: The lights of the city should be visible. If it was dead calm, yes - but when your eyes are perhaps 4 inches above the water in the trough of a 3-foot wave, and perhaps a couple of inches below the water at the crest of the 3 foot wave, and the city lights are 6 miles away, there's a good chance you'll never even see them. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Most experienced CFI runs out of gas | Robert M. Gary | Piloting | 54 | November 19th 04 01:24 AM |
Fuel dump switch in homebuilt | Jay | Home Built | 36 | December 5th 03 02:21 AM |
Sheepskin seat covers save life. | Kevin | Owning | 21 | November 28th 03 10:00 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Hot weather and autogas? | Rich S. | Home Built | 33 | July 30th 03 11:25 PM |
