Rolling a Non Aerobat 150
Old May 2nd 05, 02:15 AM
Larry Dighera
Default Rolling a Non Aerobat 150
On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in
-1G is nothing more than hanging in your belts during level
inverted flight.
Isn't also the maximum negative G limit of a C-150 operating in the
Normal category? If so, the only reason it doesn't fail, is the
safety margin in certification standard.
Old May 2nd 05, 04:45 AM
Dave Stadt
"Larry Dighera" wrote in message
inverted flight.
I doubt -1G is a limit. The 120/140 limit is -2.26 G plus a 150% safety
margin. It is nearly impossible to get a Cessna to come apart in the air.
Old May 2nd 05, 01:43 PM
Larry Dighera
On Mon, 02 May 2005 03:45:21 GMT, "Dave Stadt"
wrote in ::
inverted flight.
Isn't it also the maximum negative G limit of a C-150 operating in the
safety margin in the certification standard.
A quick perusal of the Airworthiness certificates shows a load factor
of +4-4, -1.76 for non aerobatic C-150s and +6.0, -3.0 for Aerobats.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/f9939cf761ddfa3f86256e2b0053faa3/$FILE/3a19.pdf
The 120/140 limit is -2.26 G plus a 150% safety margin.
That seems to exceed the C-150 specification.
Do you have some data to support that, or is that opinion empirically
derived? :-)
Old May 2nd 05, 01:56 PM
Jose
derived? :-)
"empirical" means "by experiment" (data). As opposed to "by theory"
(mathematics and modelling)
Jose
Get high on gasoline: fly an airplane.
Old May 2nd 05, 02:08 PM
Larry Dighera
On Mon, 02 May 2005 12:56:55 GMT, Jose
wrote in ::
derived? :-)
While what you assert is true, given Merriam-Webster's definition:
Main Entry:empirical
Pronunciation:-i-k*l
Variant:also empiric \-ik\
Function:adjective
Date:1569
1 : originating in or based on observation or experience
*empirical data*
2 : relying on experience or observation alone often without due
regard for system and theory
3 : capable of being verified or disproved by observation or
experiment *empirical laws*
4 : of or relating to empiricism
–empirically \-i-k(*-)l*\ adverb
I wonder why you felt the need to define the meaning of the word.
What was your point?
Old May 2nd 05, 02:20 PM
Jose
derived? :-)
...given [webster's definition, consistant with my statement]
It was a UU. ("usenet urge"). The original quote seemed to misuse the
word, pitting "empirical" against "having some data", when they mean the
same thing.
The usage I would expect would be something like "is there any theory
behind this, or is that opinion empirically derived?" or "do you have
some data to support that, or is this merely a theoretically based opinion?"
Jose
Old May 2nd 05, 02:31 PM
Larry Dighera
On Mon, 02 May 2005 13:20:06 GMT, Jose
wrote in ::
derived? :-)
same thing.
Jose
Oh, for a minute there, I thought you were attempting to define all
data as empirical.
Old May 2nd 05, 02:36 PM
Jose
data as empirical.
No. Only high altitude pressurized data.
Jose
Old May 2nd 05, 10:18 PM
Dave Stadt
wrote in ::
inverted flight.
Yep, 2.26 is further from 0 than is 1.76.
derived? :-)
The NTSB has the data. Those attempting to win a Darwin award would do well
to avoid Cessnas.
Old May 2nd 05, 10:52 PM
george
wrote in ::
in
inverted flight.
in the
factor
Aerobats.
empirically
derived? :-)
do well
to avoid Cessnas.
The older C150s are rated at +4.4 / -1.76 g and you'd be pushing to get
anywhere over either number
Rolling a Non Aerobat 150 Jose Piloting 1 May 2nd 05 03:59 PM
Rolling a Non Aerobat 150 Larry Dighera Piloting 1 April 29th 05 07:31 PM
Rolling a Non Aerobat 150 kage Owning 0 April 29th 05 04:26 AM
Rolling a Non Aerobat 150 Larry Dighera Piloting 4 April 28th 05 05:06 PM
??Build rolling tool chest? Michael Horowitz Owning 15 January 27th 05 04:56 AM
