CAT II Minimums on a CAT I Approach
Old July 24th 03, 05:03 AM
Ryan Ferguson
Ron Rosenfeld wrote:
The FAA has granted authorization to both Part 91 and Part 125 operators to
use less than standard minimums on CAT I ILS's. A few years ago, when I
went through the CAT II authorization process in my Mooney, my recollection
was that this was not possible for my a/c. If I recall correctly, the
issue was that the various waivers were authorized to be issued for my
performance of CAT II approaches at CAT II runways. However, there was no
similar waiver authority to allow special CAT I minimums with the equipment
I had in my a/c.
Very interesting. So if I understand this correctly (and maybe I don't,)
you're saying that you obtained authorization for CAT II approaches, but no
waiver for CAT I minimums with the equipment on-board your Mooney? If so,
which required equipment were you lacking?
Before you even go flying, the Fed's also do an inspection of the aircraft
to ensure that all the equipment requirements are met.
What are the equipment requirements?
In addition, the standard for flying the approach is no more than 1/4 scale
deflection of either LOC or GP needles. That may be more rigorous than the
Instrument PTS, but I don't have that information handy.
It is... the instrument rating PTS allows no more than 3/4 scale deflection on
the final approach segment of the ILS.
It was an interesting experience.
Like Richard, I am curious as to why you decided to do this and what, if any
utility you've gained from the Cat II authorization you were granted. I've
tossed the idea of pursuing this around for a little bit - mainly just for the
challenge and learning experience.
-Ryan
Old July 24th 03, 05:30 AM
Ron Rosenfeld
You understand correctly. Required equipment includes an autopilot
approach coupler, HUD or FD system that provides guidance to DH. While
this stuff is also "required" for CAT II operations, one can obtain a
waiver for a CAT A a/c under Part 91. There is no similar authority to
obtain a waiver for special Cat I minima.
Unfortunately, it's not easy for me to do a cut and paste because of the
columns in the pdf document. But you can find 8700.1 on the FAA web site.
Look in Volume 2 Chapter 59 and that info is there. Any well-equipped GA
a/c should probably qualify. On my airplane, I had to add an alternate
static air source. I also had to adjust the rigging of my flaps as the a/c
tended to turn enough to one side that I had difficulty flying that last
100'. I never noticed it flying CAT I approaches.
For me it was mostly the challenge and learning experience. But it did
give me additional confidence, skill and some added utility.
The perfect approach Capt.Doug Home Built 25 December 3rd 04 03:37 AM
LSA Approach speeds Ace Pilot Home Built 0 February 3rd 04 05:38 PM
Why is ADF required on ILS approach? Rich Raine Instrument Flight Rules 27 August 1st 03 05:14 PM
NDB approaches -- what are they good for? Dylan Smith Instrument Flight Rules 15 July 10th 03 09:15 PM
Download approach charts Ron Natalie Home Built 0 July 9th 03 08:29 PM
