On 4-May-2005, Scott D. wrote:
The longer you wait to do this, the cooler the engine is getting and carb heat becomes less effective. I agree that applying carb heat quickly after experiencing power loss is critical, but not because the ENGINE cools rapidly -- it doesn't. The heat for carb heat comes from he exhaust system, which does cool rapidly if the engine is producing little or no power. -- -Elliott Drucker |
![]() On 5-May-2005, Scott D. wrote: I agree that applying carb heat quickly after experiencing power loss is critical, but not because the ENGINE cools rapidly -- it doesn't. The heat for carb heat comes from he exhaust system, which does cool rapidly if the engine is producing little or no power. Your right. My whole point was that you are no longer producing heat thus things start cooling down. Yes, I know that carb heat comes from a shroud that is around the exhaust. I didnt think that I had to get technical here. But I guess for some I have to. I'm not trying to be picky. On the other hand, I think it's just a good idea that if we intend to share knowledge on this newsgroup that we be as accurate as possible. Of course YOU know it's really the exhaust system that provides the heat, but some less experienced pilots or pilot wannabes may not. From a safety standpoint, this is not a trivial point. -- -Elliott Drucker |
On Thu, 05 May 2005 18:14:30 GMT, wrote:
On 5-May-2005, Scott D. wrote: I agree that applying carb heat quickly after experiencing power loss is critical, but not because the ENGINE cools rapidly -- it doesn't. The heat for carb heat comes from he exhaust system, which does cool rapidly if the engine is producing little or no power. Your right. My whole point was that you are no longer producing heat thus things start cooling down. Yes, I know that carb heat comes from a shroud that is around the exhaust. I didnt think that I had to get technical here. But I guess for some I have to. I'm not trying to be picky. On the other hand, I think it's just a good idea that if we intend to share knowledge on this newsgroup that we be as accurate as possible. Of course YOU know it's really the exhaust system that provides the heat, but some less experienced pilots or pilot wannabes may not. From a safety standpoint, this is not a trivial point. Point taken ![]() Scott D To email remove spamcatcher's |
