Leaving Usnet Groups, Bye
Old May 5th 05, 10:57 PM
Morgans
Andrew, check your settings. I believe that you are posting in HTML,
instead of the preferred plan text.
Jim in NC
Old May 6th 05, 06:06 PM
Andrew Gideon
I'm not (or at least not in the message to which you replied). The content
type of the message to which you replied was:
text/plain; charset=utf-8
I suspect instead that you're experiencing some difficulty with the
character set, but that's pretty much a guess.
My default character set is standard ascii. However, when I quote someone
I'm occasionally forced to use utf-8. I've not figured out why.
If there was some different message you think I posted in HTML, please give
me a message ID or something else I can use to identify it. I'd be happy
to check, just in case I am. But I've certainly told my newsreader to not
do so.
Thanks...
- Andrew
Old May 6th 05, 08:00 PM
Peter Duniho
"Andrew Gideon" wrote in message
agonline.com...
give
do so.
He probably is under the mistaken impression that you used HTML because your
post showed up in his newsreader with a different font that what he's used
to. Outlook Express, for example, uses a proportional-spaced font for plain
text 8-bit posts, even when you've set it to use a fixed-spaced font for
plain text posts.
Since HTML posts are usually in a proportional-spaced font, a person might
(incorrectly) assume that any post shown in a proportional-spaced font is
HTML.
As for why YOUR news reader insists on using 8-bit when 7-bit would do, I
don't know. You'd have to ask the KNode folks about that. I didn't see
anything in the post you made in 8-bit, nor the post to which you replied
(which was itself 7-bit) that would have suggested 8-bit encoding needed to
be used.
Pete
Old May 6th 05, 11:45 PM
Andrew Gideon
your post showed up in his newsreader with a different font that what he's
used
plain text 8-bit posts, even when you've set it to use a fixed-spaced font
for plain text posts.
Ah. Thanks. I'd thought that it might have been the font, but I didn't
have the background to explain how it could be the case; I know
little-to-nothing about MSFT products. More, I'm sufficiently stuck in my
ways that I've tried very few NNTP readers even on my platform of choice.
to be used.
I'd always assumed that it was because I was quoting from an 8-bit message.
However, this incident caused me to check and that is not the case.
Puzzling.
- Andrew
Leaving Usnet Groups, Bye NW_PILOT Owning 224 May 7th 05 04:07 PM
So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money [email protected] Owning 1 January 16th 05 06:48 AM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
