When Auburn plugs were available we used to use them
exclusively. They lasted much longer than the Champs. Then Champion bought them up and shut them down. We'd formerly had a lot of trouble with Champions failing the testing at 50 or 100 hours, and it seemed to be the spring-loaded internal resistor that somehow lost its contact, even though I could see nothing wrong with it in any plug that wouldn't spark. I'd even had Champions failing right out of the box. We started using the Unisons when they came out. They had the same monolithic (molded-in) resistor the Auburns had used, and worked well. In the last year we've had trouble with them misfiring, and on the test stand they will arc in the cigarette barrel; the spark would rather jump from the contact button to the shell rather than across the gap at 120 psi. I think it's another resistor problem. Misfiring plugs aren't always readily apparent. You might feel the slightest bit of roughness, usually in climb or leaned cruise, and if the mags aren't timed exactly together. As the earlier plug fires and the cylinder pressures start to rise, the other can't or won't fire and you have a slower burn in that cylinder. Switching from BOTH to LEFT or RIGHT won't detect anything. We're using both Champs and Unisons right now to see what the eventual outcome might be. Dan |
Unison spark plugs | Ed Sullivan | Home Built | 3 | April 21st 05 02:10 PM |
Owner Change/rotate spark plugs? | Victor J. Osborne, Jr. | Owning | 34 | February 25th 05 07:19 PM |
Bougies blindées BG à vendre/BG spark plugs for sale | stef | General Aviation | 0 | May 14th 04 04:57 PM |
Color of spark plugs | john smith | Owning | 5 | March 2nd 04 03:08 AM |
Spark plugs for ASH26E | Ludovic Launer | Soaring | 4 | February 3rd 04 07:56 PM |
