![]() "A Guy Called Tyketto" wrote in message m... If ATC tells you to remain outside a certain class airspace, you must read that back and remain outside that airspace until he clears you into it. If ATC tells you to remain outside you have to remain outside, whay requires you to read it back? RADAR CONTACT is not required. Altimeter setting is not required. Readback is not required. You know he hears you because he responded to your radio call with your call sign. I'm having a hard time following your argument. Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that: 3-2-3.e: ATC Clearances and Separation. An ATC clearance is required to enter and operate within Class B airspace. VFR pilots are provided sequencing and separation from other aircraft while operating within Class B airspace. For Class C, AIM 3-2-4.3 states that 2-way comms must be established, and that is the clearance into/through Class C. But, if ATC tells you to remain outside of it, you *MUST* remain outside of it until told otherwise. Plus, a readback of that would be required. Where's the requirement for radar contact? Where's the requirement for a readback? |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Steven P. McNicoll wrote: "A Guy Called Tyketto" wrote in message m... If ATC tells you to remain outside a certain class airspace, you must read that back and remain outside that airspace until he clears you into it. If ATC tells you to remain outside you have to remain outside, whay requires you to read it back? Because if you don't read it back, they have no way to know that you have acknowledged their call to you. Would you want ATC to keep repeating the same call to you, adding more radio congestion to a frequency they are already busy on? If they're trying to provide separation that your jaunt through their airspace could jeopardize, they're bloody well are goign to look for hearing a readback from you on it, and make sure that you are still outside their airspace. RADAR CONTACT is not required. Altimeter setting is not required. Readback is not required. You know he hears you because he responded to your radio call with your call sign. I'm having a hard time following your argument. Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that: 3-2-3.e: ATC Clearances and Separation. An ATC clearance is required to enter and operate within Class B airspace. VFR pilots are provided sequencing and separation from other aircraft while operating within Class B airspace. For Class C, AIM 3-2-4.3 states that 2-way comms must be established, and that is the clearance into/through Class C. But, if ATC tells you to remain outside of it, you *MUST* remain outside of it until told otherwise. Plus, a readback of that would be required. Where's the requirement for radar contact? Where's the requirement for a readback? For class C, they will always tell you 'radar contact location, say altitude'. Class B, they'll tell you 'radar contact location, cleared through/into xxx Class B airspace' along with an altimeter setting for the major airport in their area. That is a requirement for ATC to give you when entering Class B or C airspace. See the 7110.65, sections 5-3-1 through 5-3-6. There's the requirement. If they tell you to remain outside a given airspace, you had best readback that you are remaining outside that airspace. 7-9-2 gives leeway for the readback. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (GNU/Linux) iD8DBQFCe/PGyBkZmuMZ8L8RAgXEAKDRqFO8uFqW9JnKp9islutOlzKfIACg n7i8 9Yt/ya39wYpK1n3Jypc1j0E= =PIJy -----END PGP SIGNATURE----- |
![]() "A Guy Called Tyketto" wrote in message ... Because if you don't read it back, they have no way to know that you have acknowledged their call to you. They know I've acknowledged their call when I respond with "Roger." Would you want ATC to keep repeating the same call to you, adding more radio congestion to a frequency they are already busy on? Why would they repeat a call that I've acknowledged? If they're trying to provide separation that your jaunt through their airspace could jeopardize, they're bloody well are goign to look for hearing a readback from you on it, and make sure that you are still outside their airspace. No they're not. All they want is acknowledgement. Why do you want to increase frequency congestion with unnecessary readbacks? Do you understand the difference between acknowledgement and a readback? For class C, they will always tell you 'radar contact location, say altitude'. Class B, they'll tell you 'radar contact location, cleared through/into xxx Class B airspace' along with an altimeter setting for the major airport in their area. That is a requirement for ATC to give you when entering Class B or C airspace. See the 7110.65, sections 5-3-1 through 5-3-6. There's the requirement. If they tell you to remain outside a given airspace, you had best readback that you are remaining outside that airspace. 7-9-2 gives leeway for the readback. The controller is required to inform you that you're in radar contact once radar contact has been established, but there's no requirement to establish radar contact prior to entry in Class B or Class C airspace. |
A Guy Called Tyketto wrote:
If ATC tells you to remain outside you have to remain outside, whay requires you to read it back? Because if you don't read it back, they have no way to know that you have acknowledged their call to you. Believe me, if ATC gives me an instruction and unless I respond to the contrary they assume that I've heard and will comply. The sole exception to this is runway hold-short/crossing restrictions. Where's the requirement for radar contact? Where's the requirement for a readback? For class C, they will always tell you 'radar contact location, say altitude' No they won't. Not in any stretch. They'll only tell you radar contact if you are indeed in radar contact. This usually happens after a transponder code is issued etc.... None of this has anything to do with your operating in class C airspace. Class B, they'll tell you 'radar contact location, cleared through/into xxx Class B airspace' along with an altimeter setting for the major airport in their area. Again, RADAR CONTACT is a different concept from either the clearance or the altimeter setting. The altimeter setting will be that of what they are using (which may or may not be associated with an airport). That is a requirement for ATC to give you when entering Class B or C airspace. See the 7110.65, sections 5-3-1 through 5-3-6. There's the requirement. If they tell you to remain outside a given airspace, you had best readback that you are remaining outside that airspace. 7-9-2 gives leeway for the readback. No, those sections don't have anything to do with entering airspace. This is again a fundamental issue you seem to fail to want to understand. Radar service is a service. The airspace indicates where you might expect to find it, but the authorization to operate in any given airspace is NOT dependent on RADAR SERVICES being offered. I've operated out of the primary airport of a CLASS B airspace with NO RADAR SERVICE POSSIBLE (my transponder was out and their primary radar was out at the same time). |
"Ron Natalie"
A Guy Called Tyketto wrote: If ATC tells you to remain outside you have to remain outside, whay requires you to read it back? Because if you don't read it back, they have no way to know that you have acknowledged their call to you. Believe me, if ATC gives me an instruction and unless I respond to the contrary they assume that I've heard and will comply. The sole exception to this is runway hold-short/crossing restrictions. I assume you mean that you only acknowledge the transmission. Or are you saying that an instruction to change heading, climb, descend etc. won't provoke a followup response of you don't respond? Traffic alerts? I hear ATC say the call sign and their facility name all the time to pilots who don't respond to transmissions quire frequently. Where's the requirement for radar contact? Where's the requirement for a readback? Class B, they'll tell you 'radar contact location, cleared through/into xxx Class B airspace' along with an altimeter setting for the major airport in their area. Again, RADAR CONTACT is a different concept from either the clearance or the altimeter setting. The altimeter setting will be that of what they are using (which may or may not be associated with an airport). Of course. What's the "major airport" in NYC airspace? That is a requirement for ATC to give you when entering Class B or C airspace. See the 7110.65, sections 5-3-1 through 5-3-6. There's the requirement. If they tell you to remain outside a given airspace, you had best readback that you are remaining outside that airspace. 7-9-2 gives leeway for the readback. No, those sections don't have anything to do with entering airspace. This is again a fundamental issue you seem to fail to want to understand. Radar service is a service. The airspace indicates where you might expect to find it, but the authorization to operate in any given airspace is NOT dependent on RADAR SERVICES being offered. I've operated out of the primary airport of a CLASS B airspace with NO RADAR SERVICE POSSIBLE (my transponder was out and their primary radar was out at the same time). Correct, unless otherwise indicated. Some control zones require Mode C. moo |
![]() "Happy Dog" wrote in message . .. Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. |
"Steven P. McNicoll" wrote in
Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. As I said in a previous post, I'm from Canada. We have them and some require Mode C. moo |
![]() "Happy Dog" wrote in message . .. As I said in a previous post, I'm from Canada. You'd probably do well to make that distinction when you post. |
On Sat, 07 May 2005 20:48:12 GMT, "Steven P. McNicoll"
wrote: Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. Well, we have Mode C zones! There's a big ring around Boston that I generally avoid, though I am legal to fly through it without a transponder. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
Cub Driver wrote:
On Sat, 07 May 2005 20:48:12 GMT, "Steven P. McNicoll" wrote: Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. Well, we have Mode C zones! There's a big ring around Boston that I generally avoid, though I am legal to fly through it without a transponder. The Mode C veil existed at the same time control zones existed. When the airspace was "alphabetized" the term control zone was deleted in lieu of the term "surface area of controlled airspace designated for an airport" (which is pretty close to the old definition of the control zone with a lot of the flaky differences removed). |
What F-102 units were called up for Viet Nam | Tarver Engineering | Military Aviation | 101 | March 5th 06 03:13 AM |
