What size fuse for Cessna Clock?
Old May 7th 05, 04:13 AM
Scott Skylane
Mark Martindale wrote:
Thanks for the replies. My clock is like nrp's and has the rewinding
solenoid that clunks about every 2 minutes. There is only a load on it
for a fraction of a second and is too fast to measure with my dmm. I am
going to put a 1 amp fuse in and see what happens.
Mark,
The Cessna part # for the fuse is an S1091-1. This is a 1 amp *rated*
fuse. The physical *size*, however, is a little different than your
standard automotive "AGC" glass fuse. The length is the same, but the
diameter is slightly larger. These are called "AGS", and if your local
NAPA doesn't have them, your local Cessna dealer will (they are pretty
inexpensive".
Happy Flying!
Scott Skylane
N92054
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
FS2002 Clock Time Chris Simulators 0 November 6th 03 08:02 AM
