Tom Fleischman wrote:
Baloney, it contains a lot that is new. 1 - There was communication with the tower throughout the approach and the pilot was WARNED that he was too low and continued to descend anyway. Do you think that a descent rate of more than 1200 fpm (300' in 14 seconds) is normal after being warned that he was too low? Since something around 500 fpm would be more 'normal', perhaps there was something else gong on other than he "continued to descend anyway"? 2 - It appears that his medical was out of date and he was not legal to be PIC on that flight. Perhaps the web site does not have the latest data and the pilot just came from the doc? 3 - There was nothing wrong with the major aircraft systems that could be evaluated on the preliminary report suggesting that a mechanical problem was not a likely cause. Exactly - nothing on the *preliminary* report - that's why they don't stop there. This does not suggest that "mechanical problem was not likely the cause". All it says is that the preliminary report showed nothing wrong with the major aircraft systems. Do you know that his static port wasn't blocked, that his altimeter was set correctly and reading correctly, that he didn't suffer a heart attack, that the student didn't committed suicide, ... 4 - It appears that American Flyers is incapable of even keeping track of the medical currency of their instructors, a fairly simple task. See my above comment on his medical. That is gross negligence IMHO. I would consider making unsubstantiated and potentially completely false claims with minimal knowledge of the real facts gross negligence. I don't know where you get the idea that I have set myself up as judge and jury on this. Read your post again. Hilton |
"Hilton" wrote in message news:Li_ee.8399
Tom Fleischman wrote: 3 - There was nothing wrong with the major aircraft systems that could be evaluated on the preliminary report suggesting that a mechanical problem was not a likely cause. Exactly - nothing on the *preliminary* report - that's why they don't stop there. This does not suggest that "mechanical problem was not likely the cause". All it says is that the preliminary report showed nothing wrong with the major aircraft systems. Do you know that his static port wasn't blocked, that his altimeter was set correctly and reading correctly, that he didn't suffer a heart attack, that the student didn't committed suicide, ... He had an opportunity (and responsibility) to verify his altimeter reading when crossing the FAF. And when he acknowledged the low-altitude alert, the altitude he reported was consistent with ATC's radar. And regardless of his altimeter reading, he would've been well below the glideslope. He was already inexplicably low; he acknowledged a low-altitude alert while continuing to descend, taking the time to report his altimeter setting and his indicated altitude, but without mentioning any mechanical or medical problems; and then he had a heart attack, or his student carried out a murder-suicide? I think Tom is justified to conclude that such a sequence is unlikely. --Gary |
Gary Drescher wrote:
Hilton wrote: Tom Fleischman wrote: 3 - There was nothing wrong with the major aircraft systems that could be evaluated on the preliminary report suggesting that a mechanical problem was not a likely cause. Exactly - nothing on the *preliminary* report - that's why they don't stop there. This does not suggest that "mechanical problem was not likely the cause". All it says is that the preliminary report showed nothing wrong with the major aircraft systems. Do you know that his static port wasn't blocked, that his altimeter was set correctly and reading correctly, that he didn't suffer a heart attack, that the student didn't committed suicide, ... He had an opportunity (and responsibility) to verify his altimeter reading when crossing the FAF. And when he acknowledged the low-altitude alert, the altitude he reported was consistent with ATC's radar. And regardless of his altimeter reading, he would've been well below the glideslope. He was already inexplicably low; he acknowledged a low-altitude alert while continuing to descend, taking the time to report his altimeter setting and his indicated altitude, but without mentioning any mechanical or medical problems; and then he had a heart attack, or his student carried out a murder-suicide? I think Tom is justified to conclude that such a sequence is unlikely. I absolutely agree that it *appears* that the CFI messed up. Most accident sequences are pretty 'obvious', this one included. But just when you think the cause is obvious, it turns out to be something else. I've just seen too many accident reports like this to state absolutely what happened only a few days after the accident with minimal investigation. Perhaps some guy taxied into the ILS critical area by mistake? Heck, I don't know. While the 'obvious' conclusion is that the CFI screwed up, let's not trash the guy's name too early in the investigation. Hilton |
news ![]() I absolutely agree that it *appears* that the CFI messed up. Most accident sequences are pretty 'obvious', this one included. But just when you think the cause is obvious, it turns out to be something else. I've just seen too many accident reports like this to state absolutely what happened only a few days after the accident with minimal investigation. Agreed. But Tom merely stated conservatively that mechanical failure was not a "likely cause", based on the available evidence. If anything, I think that's an understatement. Perhaps some guy taxied into the ILS critical area by mistake? Heck, I don't know. Even if that happened, and went unnoticed at the time, and remains unknown to the NTSB so far, the CFI should have gone missed upon reaching the DA (according to topographic maps, the terrain at the crash site was at most a few feet higher than the TDZE). And even if his altimeter or static system *also* failed--which it didn't, given the agreement of ATC's radar with the altitude the CFI reported moments before crashing--he should have gone missed when he received the low-altitude alert. Even with latitude to speculate freely, no one here has proposed a plausible scenario consistent with the available facts that doesn't include a major blunder by the CFI during the approach. While the 'obvious' conclusion is that the CFI screwed up, let's not trash the guy's name too early in the investigation. As opposed to suggesting that his student committed a murder-suicide? ![]() any case, to propose that the CFI made a critical mistake while flying is not to accuse him of negligence or other moral culpability; I don't think it "trashes" him. Aside from the apparent in-flight mistake, Tom also impugns the CFI's judgment in undertaking the flight at all, given the reported and forecast weather conditions. I disagree with Tom's assessment there, but that's a different question--the actual cause of the crash, whatever it turns out to be, isn't relevant to whether the decision to fly was warranted by the information available to the CFI at that time; there's no need to await a final report before debating *that* question. --Gary |
"Hilton" wrote in
ink.net: snip 3 - There was nothing wrong with the major aircraft systems that could be evaluated on the preliminary report suggesting that a mechanical problem was not a likely cause. Exactly - nothing on the *preliminary* report - that's why they don't stop there. This does not suggest that "mechanical problem was not likely the cause". All it says is that the preliminary report showed nothing wrong with the major aircraft systems. Do you know that his static port wasn't blocked, that his altimeter was set correctly and reading correctly, that he didn't suffer a heart attack, that the student didn't committed suicide, ... snip The whole situation is unfortunate, and it is impossible for anyone to accurately state what happened. However, on an ILS approach, I don't believe a failed PitotStatic System would prevent the glideslope from reading fully deflected at 1 mile and 300' low. If I'm not mistaken, at 5 miles, the reading is about 50' per dot, and at 1 mile the reading is about 8' per dot. Furthermore, the fact that he is reported to have read back his altitude in response to the warning and it was within 100' of what they told him during a descent strongly implies that he did not have a blocked static port... Additionally, the fact that he was as much as 400' low outside the FAF implies that he was not properly managing the airplane for a significant amount of time. While it is not clear what exactly went wrong, there seems to be evidence that the instructor may not have been very conservative or attentive. Whether or not that was the cause of the accident or even contributed to it is impossible to say. |
Looking for a See and Avoid NTSB report | Ace Pilot | Piloting | 2 | June 10th 04 01:01 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Wellston Crash Report Quote | EDR | Piloting | 26 | November 21st 03 10:50 PM |
Report blames pilots in crash of two Navy jets | Otis Willie | Naval Aviation | 0 | September 26th 03 01:27 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
