![]() wrote: Don't tell me to install Linux. I know that. It's currently not an option. I downloaded and installed FG on a fairly capable XP system (1.6ghz AMD 256 RAM and a good video card) and was blown away by the frame rate. Like one second per frame even in the lower resolution modes? I shut down all the background tasks I can, task manager shows 99% free resources, but hey... this is windows. I've got to be doing something wrong (besides using XP). What is it? It's got to work better than this. How do you get it to run so that it's not just a big joke? I agree with Epi. You need more RAM. 256k is only enough to run XP and Word. I think you will find that 512k RAM will do a lot for the frame rate. That MB should be able to use the older 2100 or 2400 RAM. You can get a 512 stick for about $50 or less. A 256k stick can be had for cheap, cheap. John |
On 7 May 2005 06:08:35 -0700, "jmiguez" wrote:
wrote: Don't tell me to install Linux. I know that. It's currently not an option. I downloaded and installed FG on a fairly capable XP system (1.6ghz AMD 256 RAM and a good video card) and was blown away by the frame rate. Like one second per frame even in the lower resolution modes? I shut down all the background tasks I can, task manager shows 99% free resources, but hey... this is windows. I've got to be doing something wrong (besides using XP). What is it? It's got to work better than this. How do you get it to run so that it's not just a big joke? I agree with Epi. You need more RAM. 256k is only enough to run XP and Word. I think you will find that 512k RAM will do a lot for the frame rate. That MB should be able to use the older 2100 or 2400 RAM. You can get a 512 stick for about $50 or less. A 256k stick can be had for cheap, cheap. With XP and the apps that run in the back ground I'd want a minimum of 512 and preferably one gig. To the OP. Bring up the "Task manager" and see what you have for memory use and page file swapping. I'd bet it's doing a tremendous amount of page file swapping. (swapping chunks of programs and data from RAM to the HD and working piecemeal). On this machine, several upgrades back, going from 512 to 1 Gig made an unbelievable difference. I do a lot of photo processing. It went from 20 to 30 seconds on loading a 65 meg image to about a second. I can run the scanner, the canner software, Photoshop CS AND process 4 to 6 images at a time AND run Word too. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com John |
Wingtip Vortex: Heavy, Clean, Slow - Why? | Eric Nospam | Piloting | 23 | January 21st 05 03:09 AM |
Flying Slow | [email protected] | Piloting | 61 | January 17th 05 05:23 PM |
Deployments Slow Fire Training For Military Pilots | Otis Willie | Military Aviation | 0 | July 8th 04 12:19 AM |
Military Slow Routes | R22AV8R | Rotorcraft | 0 | April 17th 04 01:51 AM |
Problème de lancement de Flightgear | Nicolas Bernier | Simulators | 0 | September 22nd 03 10:10 AM |
