Electric motor assisted super- or turbocharger?
Old May 8th 05, 05:34 PM
Don Stauffer
Why not just have a small compressed air pump driven by gears from
crankshaft or camshaft, with a tank to store a few "starts" full of
compressed air? Seems like an easier fix than an electric driven
compressor.
Max Kallio wrote:
2-stroke diesels need compressed air for starting the engine, so the
turbo (exhaust driven centrifugal supercharger) is out of a guestion
and it produces very little boost at low rpm anyhow.
How about supplementing a centrifugal turbocharger with a high speed
electric motor to create boost needed for starting and to enhance
boost at low rpm?
This would pretty much eliminate the turbo lag and actually help suck
the exhaust out of the cylinder at low rpm.
When the rpm rises, the electric motor could disengage or perhaps even
work as an auxilary generator.
Also, if the turbo has some problems, the electric motor could be used
at full power to help the turbo to spin and create boost at least for
the time it takes to land safely. Of course, the engine should be
able to have enough power to stay airborne at least at low altitudes
(if the load is not exeeded) even when the turbo fails completely.
Links...
www.turbodyne.com
Old May 9th 05, 03:37 PM
Steve
compressor.
People should really study up on some of the things that have been done
with turbo- and super-chargers for the past 60 years before getting
carried away. For the last 20 years, for example, virtually all EMD
locomotive engines (2-stroke diesels) have used a hybrid
mechanical/turbo supercharger. At low power settings and during
starting, a sprag (overrunning clutch) spins the turbocharger from the
engine's own gear train, just like the old Roots blowers used to be
turned. But when the power is increased, the turbine takes over and
spins the compressor faster than the engine's drive, so the overrunning
sprag releases and the turbo is fully powered by exhaust.
Proven, simple, no silly mechanical-electrical-mechanical conversions to
go through. But the 2-stroke diesel is dead anyway. Conventional
4-stroke turbo-diesels are the present (except for ever-decreasing
production of EMD 710 engines) and the future of diesel power.
Old May 9th 05, 04:30 PM
Bob
Why is the 2 stroke diesel dead?
I know little about diesels, just the obvious, like no sparkplug.
Bob
Old May 9th 05, 06:34 PM
Steve
Bob
High emissions and lower fuel efficiency compared with competitive
4-stroke diesels
In order to get emissions down, a 2-stroke diesel engine has to be
"overblown" so that an excess of fresh air is pushed through the
cylinder to drive out the exhaust gasses fully, but doing that wastes
mechanical power. So solving the emissions problem aggravates the
efficiency problem and vice-versa. And also, 2-stroke diesels have a
lot higher lubricating oil consumption rate than similar 4-strokes, and
that aggravates emissions too.
The EMD 710 is the only remaining locomotive 2-stroke, and is being
phased out by the EMD 4-stroke "H-series" engine. Detroit Diesel was the
biggest maker of 2-strokes for trucks, earthmovers, yachts, etc. and
they stopped 2-stroke production several years ago. And its been over 20
years since many 18-wheelers used Detroit 2-strokes anyway.
Fairbanks-Morse still builds their opposed-piston 2-strokes for a few
Navy applications and for stationary applications (flood control pumps,
backup generators, etc.) and will probably continue to do so, but that's
a pretty small market segment.
Since 2 NGs are aviation related, that is one area where the 2-stroke
*might* hang on longer because of its weight savings, but its ultimately
probably doomed there also.
Old May 9th 05, 09:09 PM
Kevin Bottorff
Steve wrote in :
Bob
4-stroke diesels
20
that's
ultimately
exspecially since they are testing at least one rotary diesel, very much
lighter and quieter for unmaned small reconasinst planes. KB
ThunderSnake #9 Warn once, shoot twice
460 in the pkup, 460 on the stand for another pkup
and one in the shed for a fun project to yet be decided on
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
Desktop Wallpaper - "F/A-18F Super Hornet Sunset". T. & D. Gregor, Sr. Naval Aviation 0 December 1st 04 01:08 PM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 02:43 AM
Piper Arrow electric fuel-pump MC General Aviation 7 June 3rd 04 02:50 AM
Gyros - Electric vs Vacuum? Bill Denton Piloting 1 April 18th 04 05:56 AM
