Jim Carriere wrote: Jay Honeck wrote: Yesterday I noticed that we had pumped more than 5000 gallons of mogas through the Mighty Grape. This represents something like 60 complete fills (our plane has four gas tanks, totaling 84 gallons), and around 350 hours of flight time over the last 2.5 years. Awww, anecdotal evidence. Statistically speaking, you need a larger sample size ![]() But seriously, a good post, well documented. 'Couple questions- Do you use the same spark plugs (and same heat range) as before going to mogas? I do, too -- plugs last longer without the lead in the fuel. Do you lean, and how lean? What kind of numbers do you usually see in different regimes of flight (EGT, CHT)? Obviously detonation hasn't been a problem for you, I'm curious how hot you can get away with on that engine with regular auto fuel. Detonation is NEVER a problem when the octane is correct. If the engine is designed for 80 octane, it will happily drink 80 octane mogas or anything else that meets the minimum spec. The absence of lead in the fuel simply means that there is less junk to scavenge out of the combustion products. BTW, how many out there are aware that 80 octane unleaded avgas used to be available, back in the 40s and 50s? -- Remove _'s from email address to talk to me. |
be available, back in the 40s and 50s? -- Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... BT |
![]() BTIZ wrote: Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... Red gas was available in some places until fairly recently (historically speaking). My airport was selling it right up until 2002. Oddly enough, I saw some red gas the other day. My tiedown neighbor owns a 150 that never flies. Every few years, he spends several thousand on an annual and maintenance, then ends up not flying. The cycle repeats every other year. Just the other day he had a team of A&Ps and IA surrounding the plane on the ramp, getting it ready to fly again. He's finally selling it. When he sampled the fuel and it came out red colored, everyone on the ramp just busted out laughing. We figured he had the last surviving example of 80/87 aviation gas in the country. Too bad such rarity doesn't make his ramp queen worth any more :-( John Galban=====N4BQ (PA28-180) John Galban=====N4BQ (PA28-180) |
I got my last tankful of 80/87 at RBL about November of last year,
awhile after the last refiner stopped producing it. It had become a rarity over the last ten years or so - you had to know where to go to get it. David Johnson |
: Detonation is NEVER a problem when the octane is correct. If the engine
: is designed for 80 octane, it will happily drink 80 octane mogas or : anything else that meets the minimum spec. The absence of lead in the : fuel simply means that there is less junk to scavenge out of the : combustion products. That's not completely true. Some engines are marginal on their rated fuel (in particular, fire-breathing TGSIO-ABC-XYZ-540's putting out 350 hp or whatever). Even some planes could be marginal on their rated fuel in the worse possible condition. For example, long climb, just under redline CHT, fuel at the bottom of the permissible octane rating, carb float/jets at the leanest possible configuration, etc, etc. The bigger variable is that autofuel does not use quite the same rating as avgas. Autofuel (in the U.S. anyway) uses an (R+M)/2 rating, or anti-knock-index (A.K.I). The point spread between the two is not published, but is generally about \pm 5 points, with the lower (motor) most closely similar to the aviation method. Basically, that means that 87 AKI autogas is probably about 82 motor, 92 research. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
