![]() "Dan, U.S. Air Force, retired" wrote in message news:5R6ge.6000$aB.4725@lakeread03... I'm playing with a mechanism that involves a piece of nylon rod rotating inside an aluminum tube. Is lubrication required and if so what kind? Dan, U.S. Air Force, retired At what RPM. and what kind of loads will be on it? -- Jim in NC |
Morgans wrote:
"Dan, U.S. Air Force, retired" wrote in message news:5R6ge.6000$aB.4725@lakeread03... I'm playing with a mechanism that involves a piece of nylon rod rotating inside an aluminum tube. Is lubrication required and if so what kind? Dan, U.S. Air Force, retired At what RPM. and what kind of loads will be on it? Actually it will be cycling over an arc of 15º - 20º lateral loads won't exceed 20 pounds total over a 4 inch length. Longitudinal load is essentially zero. Cyclic rate won't exceed 5 cycles per second. Dan, U.S. Air Force, retired |
exceed 20 pounds total over a 4 inch length. Longitudinal load is essentially zero. Cyclic rate won't exceed 5 cycles per second. Make sure the Aluminum is very smooth. I wouldn't lubricate it at all. I think you'll find the nylon lives longer than the aluminum that it rides on. |
On Wed, 11 May 2005 00:53:04 GMT, "LCT Paintball"
wrote: Actually it will be cycling over an arc of 15º - 20º lateral loads won't exceed 20 pounds total over a 4 inch length. Longitudinal load is essentially zero. Cyclic rate won't exceed 5 cycles per second. Make sure the Aluminum is very smooth. I wouldn't lubricate it at all. I think you'll find the nylon lives longer than the aluminum that it rides on. grease? Stealth Pilot |
grease?
Stealth Pilot Nylon is self lubricating. It might actually perform worse with grease. |
Mooney Engine Problem in Flight - Advise | Paul Smedshammer | Owning | 17 | December 21st 04 06:39 AM |
CAI 302 repair advise needed | Jamey Jacobs | Soaring | 5 | October 19th 04 03:06 AM |
Need advise on ASA's IPT | charley | Products | 0 | December 14th 03 05:40 PM |
