ATC User Fees
Old May 10th 05, 07:05 PM
Jose
It would have to be a =much= better reason than most.
It would have to be in any case, given all the other reasons not to go to a
large Class B airport. So what?
I don't understand the question. The fees at large commercial airports
are very much higher than fees elsewhere, although I have found bargains
at times. I've landed spam cans at Logan and National for example
during times when they were holding a sale.
The high fees serve as a deterrent - to a sufficent extent that most
spam cans avoid the airport. Long taxiways do not act as strongly as a
deterrent (though I've taxiied for more than an hour at Dulles - I was
glad I was on tach time and not hobbs!). While the exec who flies his
jet into the city for an important meeting can justify a hundred dollar
landing fee, the small business owner who is also a pilot and flies a
172 is likely to have a much harder time justifying it. He's likely to
fly elsewhere and take a cab, even if it takes a bit longer.
Yes, a 172 landing in front of a line of 747s will have a strong impact
on the airport's traffic pattern, and this should be figured in. It
wouldn't be so bad if there were nearby reliever airports (or even
reliever runways), but around the big hubs, the relievers are generally
not all that close. Flushing Airport would have been nice, alas it's
gone. There's nothing in Boston except Logan. We all know about DC...
Jose
Money: what you need when you run out of brains.
Old May 10th 05, 10:00 PM
Peter Duniho
"Jose" wrote in message
I never said they weren't.
I never said they didn't.
- to a sufficent extent that most spam cans avoid the airport.
Um...isn't that what "deterrent" means? If "spam cans" didn't avoid the
airport, it wouldn't be much of a deterrent, would it?
Long taxiways do not act as strongly as a deterrent (though I've taxiied
for more than an hour at Dulles - I was glad I was on tach time and not
hobbs!).
Spending an hour taxiing isn't a deterrent for you? Um, okay.
While the exec who flies his jet into the city for an important meeting
can justify a hundred dollar landing fee, the small business owner who is
also a pilot and flies a 172 is likely to have a much harder time
justifying it. He's likely to fly elsewhere and take a cab, even if it
takes a bit longer.
"Likely not to" and "banned" are two completely different things.
Frankly, your post is simply supporting my point (well, the point I now
have, given that my question was met with zero supporting evidence regarding
the claim of "banned"). Light GA aircraft DO use the largest Class B
airports. They are NOT banned at all. If there's a good enough reason to
use the airport, they are used.
I guarantee that there is a price at which light GA aircraft would never use
a large Class B. It's at this price point which I'd consider light GA
aircraft to be "effectively banned". Below that price point, they are not
banned; they are simply discouraged, with the market showing exactly how
much landing at that airport is worth to a certain group of light GA pilots.
Pete
Old May 10th 05, 10:31 PM
Jose
Not as much as a hundred-dollar landing fee. Especially when it's only
"maybe" I'll have a long taxi, and "certainly" I'll pay $100 to land.
Correct. And "effectively banned" is different from "banned". I think
the OP was using "effectively banned" to mean "so dissuaided that most
spam cans avoid the airport". I find this usage to be accurately
descriptive and helps make his point.
Your usage ("a price at which light GA aircraft would =never= use") is
another reasonable definition, and makes your (different) point.
Arguing whether "(effectively) banned" is the correct word to use is a
silly argument about words, not an argument about the substance of the
post, which is the high degree of discouragement these fees apply to
spam can pilots wishing to fly into a major city served (only) by a
giant hub with high landing fees.
It's similar to Signature's effect on the market, and the effect of
charging for weather briefings.
Jose
Old May 11th 05, 12:01 AM
Peter Duniho
How so? Have you actually looked at the definition of "effectively"? All
the word implies is that a ban is in place without it being overt. A
nominal ban would be an actual regulation that says "no GA aircraft
allowed". An "effective ban" is one that does the same thing, through other
means.
I think the OP was using "effectively banned" to mean "so dissuaided that
most spam cans avoid the airport". I find this usage to be accurately
He hasn't stated that was his usage. However, if it was, it's contrary to
the definition of "effectively".
I will agree that redefining after the fact the terms one uses helps one
make one's point. It's a common tactic for people who say one thing, but
either mean something else or find that what they originally meant wasn't
correct in the first place.
My definition matches the actual definition of "effectively".
post, which is the high degree of discouragement these fees apply to spam
can pilots wishing to fly into a major city served (only) by a giant hub
I suppose that depends on what the actual intent of the original post was.
All I can go on is the actual words in that post. As written, the post
appears to be incorrect.
Pete
Old May 11th 05, 05:48 AM
Marty Shapiro
"Peter Duniho" wrote in
All the word implies is that a ban is in place without it being overt.
A nominal ban would be an actual regulation that says "no GA aircraft
other means.
that most spam cans avoid the airport". I find this usage to be
accurately descriptive and helps make his point.
contrary to the definition of "effectively".
one make one's point. It's a common tactic for people who say one
thing, but either mean something else or find that what they
originally meant wasn't correct in the first place.
is another reasonable definition, and makes your (different) point.
From the dictionary definition of "effectively", including the
dictionary's usage example:
"For all practical purposes; in effect: Though a few rebels still held
out, the fighting was effectively ended."
The definition does NOT equate "effectively" with "absolutely",
"totally", "completely", etc. A combination of landing & ramp fees will
effectively, but not totally, ban GA traffic.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old May 11th 05, 06:15 AM
Peter Duniho
"Marty Shapiro" wrote in message
That definition isn't in my dictionary. Wonderful for you that it's in
yours.
However, even by that definition, light GA is not "effectively banned" from
large Class B airports. The fact that large Class B airports still have
significant light GA traffic is proof of that.
Pete
Old May 11th 05, 06:28 AM
John Godwin
it's in yours.
Try here http://dictionary.reference.com/search?q=effectively
Old May 11th 05, 07:50 AM
Marty Shapiro
held
in yours.
from large Class B airports. The fact that large Class B airports
still have significant light GA traffic is proof of that.
Pete
Perhaps if you didn't go around spending $100+ to park at a large
class B airport, you could afford a better dictionary.
For free, you can use dictionary.com.
Define light GA aircraft. When I was on the ramp at SFO, they told me
I was the only piston powered aircraft to land there that day.
Marty Shapiro
Silicon Rallye Inc.
Old May 10th 05, 11:46 PM
Matt Whiting
to a large Class B airport. So what?
Actually, with controllers worth their salt, a 172 can be slipped in
between two airliners with less delay than another airliner in the same
line would induce. The one time I flew into Logan, the controller had
me fly the "something bridge visual" and I made a close-in base to maybe
a 3/4 mile final. I was in the final approach for a very short time.
And my time on the runway was far shorter than an airliner making its
roll-out.
Sure, if they line up the 172 on a 10 mile final, then you will wreak
havoc on the traffic flow, but no controller with a clue would do that.
I've flown into a number of fairly large airports (Logan, Philly, BWI,
Washington National, etc.) and I never delayed an airliner. The
controllers uniformly did an excellent job of bringing me in on a close
pattern and I either landed on a GA runway (PHL and BWI) or dropped into
the airliner chain with narry a hiccup.
Matt
Matt
Old May 11th 05, 03:50 AM
Jose
Actually, with controllers worth their salt, a 172 can be slipped in between two airliners...
Sure, if they line up the 172 on a 10 mile final...[but] The controllers uniformly did an excellent job of bringing me in on a close pattern and I either landed on a GA runway (PHL and BWI) or dropped into the airliner chain with narry a hiccup.
That's my experience too at the larger hubs. Logan was amazingly easy.
Jose
User Fees Dude Owning 36 March 19th 05 05:57 PM
NAA Fees to the US Team Doug Jacobs Soaring 2 October 29th 04 01:09 AM
LXE installation XP, strict user permissions. Hannes Soaring 0 March 21st 04 11:15 PM
The Irony of Boeing/Jeppesen Being Charged User Fees! Larry Dighera Piloting 9 January 23rd 04 12:23 PM
Angel Flight pilots: Ever have an FBO refuse to wave landing fees? Peter R. Piloting 11 August 2nd 03 01:20 AM
