The German proximity fuse.
Old May 11th 05, 02:05 AM
Gord Beaman
"M. J. Powell" wrote:
In message
, Geoffrey
Sinclair writes
snip
Method 3: making the shell body part of a resonant circuit and
detecting frequency changes.
Should be fun lugging the fused shells around metal guns.
IIRC the fuse was inactive until fired. The shock of firing broke a
glass cell containing the battery acid, the battery then produced the
required voltage.
Mike
Jesus...I'd hate to be the second guy to accidentally drop the
damned thing...
-Gord.
Keep in mind that I'm an expert with
questions, so if you have any, fire
away.
Be aware however, that answers
quite often give me trouble.
Old May 11th 05, 07:48 AM
John Keeney
"Gord Beaman" wrote in message
In message
, Geoffrey
Sinclair writes
required voltage.
Mike
damned thing...
If you think about it, the glass cell could be amazingly tough.
What would the acceleration of the initial firing be: a few thousand g'?
A piece of glass thick enough to be virtually unbreakable under
normal circumstances would shatter under its own weight if
bridging a hole.
50% of NAZI oil was supplied from US Grantland Military Aviation 106 January 18th 14 07:58 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
FDR and Bush 43 WalterM140 Military Aviation 44 June 24th 04 12:16 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
German historian provokes row over war photos BackToNormal Military Aviation 21 October 24th 03 11:32 PM
