"Marty Shapiro" wrote in message
... Define light GA aircraft. When I was on the ramp at SFO, they told me I was the only piston powered aircraft to land there that day. Hmmm...you were at SFO, in spite of the "effective ban"? Amazing. Considering how light GA is supposed to be "effectively banned", we have a surprising number of folks even in this small group of pilots who have flown into large Class B airports. As for the definition of "light GA aircraft", I'm speaking of pretty much the same planes you probably would expect: six-seat and smaller piston aircraft (singles and twins). Perhaps some of the smallest cabin-class twins. Navajos, TBM700s, King Airs, and business jets need not apply. Pete |
"Peter Duniho" wrote in
: "Marty Shapiro" wrote in message ... Define light GA aircraft. When I was on the ramp at SFO, they told me I was the only piston powered aircraft to land there that day. Hmmm...you were at SFO, in spite of the "effective ban"? Amazing. The statement was that high fees "effectively ban". Since I knew in advance that ALL fees would be waived, the issue of fees was completely irrelevant. A fee of $0.00 nullifies both the "high" and "fees" in "high fees". Considering how light GA is supposed to be "effectively banned", we have a surprising number of folks even in this small group of pilots who have flown into large Class B airports. For some reason, you have fixated on "effectively" equating to "completely" or "totally" despite being referred to a perfectly valid dictionary definition (with usage example) which says otherwise. You've also managed to drop the "high fees". Fees are a deterrent to landing at an airport. The higher the fees, the more of a deterrent they are. If you make them high enough, you effectively (but not totally) ban light GA aircraft unless no viable alternative exists. Not all large class B airports have landing fees. Of the class B airports with landing fees that I am aware of, SFO is the most expensive, (excluding surcharges). I even posted the fact that the NYC class B airports (JFK, LGA, & EWR) have a $25 landing fee with a $100 surcharge for landing or takeoff operations during certain hours. LAX and LAS have no landing fee. (All fee examples refer to light GA aircraft.) Unless you are planning to only do a touch-and-go the ramp fee has be figured in when determining if the cost of landing is a deterrent at any airport, not just a class B airport. Where the total fees are more reasonable, regardless of class of airport, you will find more GA aircraft. Given reasonable alternatives, GA aircraft will go to the airport with the lower fees. As I previously stated, LAS is a large class B airport with no landing fee. 13 years ago, other than fuel, the fees at LAS were reasonable. Parking was free for the first 6 or 8 hours and the overnight fee, which I don't recall exactly, was also quite reasonable. Back then, there were many light GA aircraft on the LAS ramp. Last July, the ramp fee at LAS was $50 daily, no "grace" period. The fee was for one night was waived with a minimum fuel purchase. However, VGT, a class D only 8.2 NM north, was $5 per night (no waiver for fuel purchase) and $1.50 per gallon less for 100LL. Guess which transient ramp was chock full of light GA aircraft and which one had very few. As for the definition of "light GA aircraft", I'm speaking of pretty much the same planes you probably would expect: six-seat and smaller piston aircraft (singles and twins). Perhaps some of the smallest cabin-class twins. Navajos, TBM700s, King Airs, and business jets need not apply. Pete Using your definition of a light GA aircraft, which I agree with, counting me there was exactly one which landed at SFO on the day I was there. (I left around 6:30 PM, so it is possible one did arrive afterwards.) The closest I saw to a light GA aircraft at SFO that day was a Piper Malibu Mirage. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
... Hmmm...you were at SFO, in spite of the "effective ban"? Amazing. The statement was that high fees "effectively ban". Since I knew in advance that ALL fees would be waived, the issue of fees was completely irrelevant. A fee of $0.00 nullifies both the "high" and "fees" in "high fees". Okay, I failed to connect those two. Sorry. Considering how light GA is supposed to be "effectively banned", we have a surprising number of folks even in this small group of pilots who have flown into large Class B airports. For some reason, you have fixated on "effectively" equating to "completely" or "totally" despite being referred to a perfectly valid dictionary definition (with usage example) which says otherwise. You've also managed to drop the "high fees". The usage example provided here doesn't come close to justifying the statement as applied to large Class B airports. As far as dropping the "high fees" statement, I'm not really sure what you're talking about. The original statement made a claim only with respect to "landing fees", and while I have not made a conscious effect to distinguish between landing fees and other fees, accusing me of some sort of underhanded position shifting makes no sense whatsoever. Fees are a deterrent to landing at an airport. The higher the fees, the more of a deterrent they are. If you make them high enough, you effectively (but not totally) ban light GA aircraft unless no viable alternative exists. You would see fewer light GA aircraft at large Class B airports, even if the fees were zero. Furthermore, you (and the others) insist that "effectively" doesn't mean "actually", but you apparently refuse to explain just how many planes can be permitted at an airport before there's no "effective ban". You've got a great slippery-slope argument going, but when you look at small airports with fees that also discourage light GA aircraft (or any other, for that matter), you've either got to claim light GA aircraft are "effectively banned" there (which would obviously make no sense), or explain what makes those airports different from the others where light GA aircraft are "effectively banned" (ie, what sort of light GA traffic does an airport need to see before one doesn't consider it "effectively banned"). If you want to continue talking about this "effective ban", your first step is to define what that means. Clearly light GA aircraft are using the largest Class B airports in the US, so they clearly are not really banned. Since you feel you can equivocate on the definition of "effective", you need to explain just where you're going to draw the line. Otherwise, the definition you're using can be taken to ridiculous limits. Once you've defined your "effective ban", then you need to illustrate that by showing exactly how many light GA aircraft are using the largest Class B airports, and that that number is dramatically different from the number that would be using those airports if there were not any fees (comparing a large Class B airport to even a local reliever, never mind a small GA-only airport, won't prove anything). Only one person so far has even pretended to provide actual data supporting his thesis, and the data turned out to be bogus. It's hardly a convincing way to demonstrate one's point. I remain unconvinced that light GA aircraft are "effectively banned" from any airport, due to landing fees or otherwise. Pete |
: "Marty Shapiro" wrote in message ... Hmmm...you were at SFO, in spite of the "effective ban"? Amazing. The statement was that high fees "effectively ban". Since I knew in advance that ALL fees would be waived, the issue of fees was completely irrelevant. A fee of $0.00 nullifies both the "high" and "fees" in "high fees". Okay, I failed to connect those two. Sorry. Considering how light GA is supposed to be "effectively banned", we have a surprising number of folks even in this small group of pilots who have flown into large Class B airports. For some reason, you have fixated on "effectively" equating to "completely" or "totally" despite being referred to a perfectly valid dictionary definition (with usage example) which says otherwise. You've also managed to drop the "high fees". The usage example provided here doesn't come close to justifying the statement as applied to large Class B airports. As far as dropping the "high fees" statement, I'm not really sure what you're talking about. The original statement made a claim only with respect to "landing fees", and while I have not made a conscious effect to distinguish between landing fees and other fees, accusing me of some sort of underhanded position shifting makes no sense whatsoever. Please re-read what you stated and which I quoted in my reply. When you referred to the surprising number of pilots in this group who have flown into class B airports, you left out the qualifier "high fee". If a surprising number of pilots in this group have flown a light GA aircraft into a high fee class B, and they had to pay the fee, that would support your argument. Just flying into a class B does not, as there are class B airports with no fees. Fees are a deterrent to landing at an airport. The higher the fees, the more of a deterrent they are. If you make them high enough, you effectively (but not totally) ban light GA aircraft unless no viable alternative exists. You would see fewer light GA aircraft at large Class B airports, even if the fees were zero. Really? This will really surprise at least two Class B with over 100 single engine aircraft based there. Of course, these class B do NOT charge a landing fee to light GA aircraft. Lets take a look at data from AirNav for 2 high fee and 2 zero fee class B airport: High fee 1: Aircraft based on the field: 18 Single engine airplanes: 1 Multi engine airplanes: 3 Jet airplanes: 12 Helicopters: 2 Aircraft operations: avg 965/day 70% commercial 25% air taxi 5% transient general aviation 1% military High fee 2: (AirNav shows no aircraft based here) Aircraft operations: avg 760/day 87% air carriers 11% commuters 2% transient general aviation 1% military No fee 1: Aircraft based on the field: 263 Single engine airplanes: 115 Multi engine airplanes: 55 Jet airplanes: 45 Helicopters: 16 Military aircraft: 32 Aircraft operations: avg 886/day 55% commercial 24% transient general aviation 15% air taxi 5% military 2% local general aviation No fee 2: Aircraft based on the field: 237 Single engine airplanes: 118 Multi engine airplanes: 39 Jet airplanes: 55 Helicopters: 15 Military aircraft: 10 Aircraft operations: avg 1802/day 72% commercial 12% air taxi 11% transient general aviation 4% local general aviation 1% military If a location is served by both a class B airport and a class C, D, or G reliever airport, and assuming that fees are and location access are comparable between the class B and the reliever airport, I suspect most light GA aircraft pilots would not go to the class B. But, if my experience as a pilot who learned an flew for many years out of what is now a class C airport (it was an ARSA airport when I was a student) comparing notes with pilots who learned at class G airports is typical, I suspect there is a factor of unfamiliarity with big airports and the co- requisite radio communications biasing this decision. Furthermore, you (and the others) insist that "effectively" doesn't mean "actually", but you apparently refuse to explain just how many planes can be permitted at an airport before there's no "effective ban". You've got a great slippery-slope argument going, but when you look at small airports with fees that also discourage light GA aircraft (or any other, for that matter), you've either got to claim light GA aircraft are "effectively banned" there (which would obviously make no sense), or explain what makes those airports different from the others where light GA aircraft are "effectively banned" (ie, what sort of light GA traffic does an airport need to see before one doesn't consider it "effectively banned"). If you want to continue talking about this "effective ban", your first step is to define what that means. Clearly light GA aircraft are using the largest Class B airports in the US, so they clearly are not really banned. Since you feel you can equivocate on the definition of "effective", you need to explain just where you're going to draw the line. Otherwise, the definition you're using can be taken to ridiculous limits. If the airport is public use, it can not legally ban light GA aircraft. All it can do is highly discourage them from landing. One method of discouraging light GA aircraft from landing is to impose a high fee. However, if they make the fee prohibitive enough to achieve a complete ban (which is probably impossible as there is always some one with deep enough pockets who could pay it) they would then run afoul of the FAA. One airport authority tried this at their class B and got slammed down by the FAA. If you want a definition, I'll give you one. If there are viable reliever airport(s) at a location with a class B airport, a fee which effectively bans light GA aircraft at the class B is one where 98% of the transient light GA aircraft operations at that location take place at the reliever airport(s). Once you've defined your "effective ban", then you need to illustrate that by showing exactly how many light GA aircraft are using the largest Class B airports, and that that number is dramatically different from the number that would be using those airports if there were not any fees (comparing a large Class B airport to even a local reliever, never mind a small GA-only airport, won't prove anything). See the above data from AirNav contrasting high fee class B with no fee class B. Only one person so far has even pretended to provide actual data supporting his thesis, and the data turned out to be bogus. It's hardly a convincing way to demonstrate one's point. I remain unconvinced that light GA aircraft are "effectively banned" from any airport, due to landing fees or otherwise. Pete -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
... if they make the fee prohibitive enough to achieve a
complete ban (which is probably impossible as there is always some one with deep enough pockets who could pay it) they would then run afoul of the FAA. One airport authority tried this at their class B and got slammed down by the FAA. Which airport? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Jose wrote:
Which airport? Dunno if it's what Marty had in mind, but Massport tried that at Logan in the early 90s, and the FAA did indeed tell them to change the fee structure. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
On Thu, 12 May 2005 00:04:12 GMT, Jose
wrote in : : Which airport? Would it be located in NJ? |
Jose wrote in
: ... if they make the fee prohibitive enough to achieve a complete ban (which is probably impossible as there is always some one with deep enough pockets who could pay it) they would then run afoul of the FAA. One airport authority tried this at their class B and got slammed down by the FAA. Which airport? Jose Massport - Logan (BOS) in 1988. Basically, it's ok to have a landing fee based on weight, but you can't discriminate. So, if you say charge $1 per 1000 pounds, a light GA aircraft would pay $3 while a 747 would pay about $800. If you try to adjust the weight rate to price out the little guy, you will also price out the airlines. What Massport did was add a "per landing" fee to the weight fee. This was ruled by DOT/FAA to be unreasonable, discriminatory, and preempted by Federal law. Massport appealed but the U.S. Court of Appeals, 1st Circuit, upheld DOT/FAA. An interesting result of the ruling was a DOT/FAA opinion that if an airport can document congestion delays during certain times, it can then implement a congestion surcharge to ALL arrivals during these times. (There are a few permitted exemptions, but scheduled airline is not one of them.) However, it can only do so during the hours that the documented congestion exists. It can't, as Massport tried to do, apply the surcharge 27-7. Currently, I am aware of JFK, EWR, and LGA using a congestion time surcharge. From the Federal Reserve Bank of Boston Regional Review, Winter 1997: "Logan's landing fees, like those of virtually all U.S. airports, do not reflect congestion. Fees are based instead on weight. So a typical wide-body jet pays roughly $800 while the smallest plane, which causes as much congestion, pays $25. In 1988, Massport did try a fee scheme that combined aircraft weight with an additional fee per landing. Flights by smaller planes became relatively more expensive, and their use of Logan dropped substantially, although that reduction was also affected by industry consolidations. The scheme ended after it was judged discriminatory against small planes by the U.S. Department of Transportation, which noted that small aircraft paid higher prices even at hours when there was ample runway capacity. At the same time, the agency ruling opened the door to peak-load pricing, noting that "it may be appropriate to raise fees in order to invoke market responses during periods when the airport is congested."" Another reference you may find interesting is the FAA's letter to Massport of June 10, 2004 available at: http://web.nbaa.org/public/ops/airpo...er20040610.pdf -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
Which airport [was rebuked by the FAA for discriminatory fees]?
Massport - Logan (BOS) in 1988. A few comments from airnav about Logan (BOS): Nov 2004: $391 in fees for an overnight stay. $160 ramp, $42 GPU, $48 security fee, $52 parking, $22 Mass. GA fee and and extra $70 worth of something-or-other fees. [note - unspecified aircraft type - GPU hints it might be a jet?] Nov 2003: $43.30 security fee, $27.50 landing fee, $22 MA General Aviation fee (this is a new fee at KBOS), $27.50 parking fee, and $22 handling fee. [a three hour stay, unspecified type] I don't know what this "security fee" is but in 2003 there were noises that if you made noise you could get it waived. So, I guess they found another way to discriminate. Hire Signature to do it for you. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
... Lets take a look at data from AirNav for 2 high fee and 2 zero fee class B airport: [snipped] The data you posted simply supports my point. Even at the no-fee airports, there aren't that many airplanes (especially considering the size of the airport). 100 planes just isn't that many. There are plenty of reasons to stay away from large Class B airports other than landing fees. But regardless, looking at based aircraft isn't relevant. What you want is operations. And the data you show don't actually suggest an "effective ban". At one "high fee" airport, GA makes up 5% of the traffic, with the "no fee" airports showing only between 11% and 24%. That's hardly a slam dunk for the point you're trying to make. If the airport is public use, it can not legally ban light GA aircraft. All it can do is highly discourage them from landing. Yes. One method of discouraging light GA aircraft from landing is to impose a high fee. Yes. However, if they make the fee prohibitive enough to achieve a complete ban (which is probably impossible as there is always some one with deep enough pockets who could pay it) they would then run afoul of the FAA. One airport authority tried this at their class B and got slammed down by the FAA. Airports have had trouble imposing unreasonable fees, yes. But one would think that the FAA would consider a fee high enough to "ban light GA for all practical purposes" to be unreasonable. After all, that's the point of their objection. If anything, that state of affairs suggests that no airports "effectively ban" light GA. If you want a definition, I'll give you one. If there are viable reliever airport(s) at a location with a class B airport, a fee which effectively bans light GA aircraft at the class B is one where 98% of the transient light GA aircraft operations at that location take place at the reliever airport(s). That definition has no logical validity, since it ignores reasons for using the reliever airport unrelated to the landing fee. See the above data from AirNav contrasting high fee class B with no fee class B. I did. It doesn't support what you're saying. Pete |
User Fees | Dude | Owning | 36 | March 19th 05 05:57 PM |
NAA Fees to the US Team | Doug Jacobs | Soaring | 2 | October 29th 04 01:09 AM |
LXE installation XP, strict user permissions. | Hannes | Soaring | 0 | March 21st 04 11:15 PM |
The Irony of Boeing/Jeppesen Being Charged User Fees! | Larry Dighera | Piloting | 9 | January 23rd 04 12:23 PM |
Angel Flight pilots: Ever have an FBO refuse to wave landing fees? | Peter R. | Piloting | 11 | August 2nd 03 01:20 AM |
