On Wed, 11 May 2005 18:15:26 -0700, "Peter Duniho"
wrote in :: At one "high fee" airport, GA makes up 5% of the traffic, with the "no fee" airports showing only between 11% and 24%. That's hardly a slam dunk for the point you're trying to make. It's a 100% to 500% difference. |
"Larry Dighera" wrote in message
... It's a 100% to 500% difference. So what? Twice as much traffic one place as the other does not prove an "effective ban". |
"Peter Duniho" wrote in
: "Marty Shapiro" wrote in message ... Lets take a look at data from AirNav for 2 high fee and 2 zero fee class B airport: [snipped] The data you posted simply supports my point. Even at the no-fee airports, there aren't that many airplanes (especially considering the size of the airport). 100 planes just isn't that many. There are plenty of reasons to stay away from large Class B airports other than landing fees. I was comparing high fee class B with no fee class B, not class B with non-class B. The data shows that either no fee class B airports have more than 100 times the based single engine aircraft as the class B airport with high fees. That's on the order of 10,000% more single engine aircraft based at each no fee field. If we combine the based single engine aircraft at both no fee fields as opposed to those based at both high fee fields, you get 23,200% more based aircraft at the no fee fields. But regardless, looking at based aircraft isn't relevant. What you want is operations. And the data you show don't actually suggest an "effective ban". At one "high fee" airport, GA makes up 5% of the traffic, with the "no fee" airports showing only between 11% and 24%. That's hardly a slam dunk for the point you're trying to make. Unless the based aircraft are permanently grounded, they contribute to the airport's operation count every time they fly. They do not show up in the transient GA traffic count. If they were to be included, the GA percentage would be much higher at the two no fee class B airports as they both have flight schools. The 5% transient GA traffic at the high fee airport are almost all private jet or turbo prop aircraft, none of which are light GA aircraft. Using the day I was there, light GA aircraft accounted for only 2% of the GA traffic. The transient GA traffic counts (and disregarding the size of the aircraft), comprises 1/4 of the traffic at one of the no fee class B airports while at one of the high fee class B airports it is only 1/20 of the traffic. To put these numbers in perspective, The 24% transient GA traffic at the no fee airport results in over 58,000 more operations per year than at the 5% GA traffic high fee airport. If the airport is public use, it can not legally ban light GA aircraft. All it can do is highly discourage them from landing. Yes. One method of discouraging light GA aircraft from landing is to impose a high fee. Yes. However, if they make the fee prohibitive enough to achieve a complete ban (which is probably impossible as there is always some one with deep enough pockets who could pay it) they would then run afoul of the FAA. One airport authority tried this at their class B and got slammed down by the FAA. Airports have had trouble imposing unreasonable fees, yes. But one would think that the FAA would consider a fee high enough to "ban light GA for all practical purposes" to be unreasonable. After all, that's the point of their objection. If anything, that state of affairs suggests that no airports "effectively ban" light GA. If you want a definition, I'll give you one. If there are viable reliever airport(s) at a location with a class B airport, a fee which effectively bans light GA aircraft at the class B is one where 98% of the transient light GA aircraft operations at that location take place at the reliever airport(s). That definition has no logical validity, since it ignores reasons for using the reliever airport unrelated to the landing fee. You are now obtusely ducking the issue. I intentionally did NOT attempt to address other factors. All I attempted to address was the issue of fees incurred on landing (landing fee, parking fee) vis-a-vis the decision to land or not to land at a high fee class B airport. If you want to now throw in other factors, further discussion on the original issue is pointless. There is no definition which you won't dismiss with "no logical validity" when you can't justify not agreeing with it. Obviously, that's your game. Just as there are reasons to use the reliever unrelated to the landing fees, so are there equally good reasons to use the class B unrelated to the landing fees. The only way to determine if the landing fees are determinant in the light GA aircraft choosing the class B or the reliever is to remove these other factors. I gave you a real world example at one location where the reliever was similarly located and provided similar accessability to the city as the class B. The lower fees at the reliver pulled in most of the transient light GA aircraft. Neither airport in this case had landing fess. The reliever was $45 less per night to park and $1.50 less per gallon for 100LL. See the above data from AirNav contrasting high fee class B with no fee class B. I did. It doesn't support what you're saying. You simply looked at absolute numbers without analyzing them. Pete -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
User Fees | Dude | Owning | 36 | March 19th 05 05:57 PM |
NAA Fees to the US Team | Doug Jacobs | Soaring | 2 | October 29th 04 01:09 AM |
LXE installation XP, strict user permissions. | Hannes | Soaring | 0 | March 21st 04 11:15 PM |
The Irony of Boeing/Jeppesen Being Charged User Fees! | Larry Dighera | Piloting | 9 | January 23rd 04 12:23 PM |
Angel Flight pilots: Ever have an FBO refuse to wave landing fees? | Peter R. | Piloting | 11 | August 2nd 03 01:20 AM |
