ATC User Fees
Old May 12th 05, 02:46 AM
Marty Shapiro
Jose wrote in
... if they make the fee prohibitive enough to achieve a
complete ban (which is probably impossible as there is always some
one with deep enough pockets who could pay it) they would then run
afoul of the FAA. One airport authority tried this at their class B
and got slammed down by the FAA.
Which airport?
Jose
Massport - Logan (BOS) in 1988.
Basically, it's ok to have a landing fee based on weight, but you
can't discriminate. So, if you say charge $1 per 1000 pounds, a light GA
aircraft would pay $3 while a 747 would pay about $800. If you try to
adjust the weight rate to price out the little guy, you will also price out
the airlines. What Massport did was add a "per landing" fee to the weight
fee. This was ruled by DOT/FAA to be unreasonable, discriminatory, and
preempted by Federal law. Massport appealed but the U.S. Court of Appeals,
1st Circuit, upheld DOT/FAA.
An interesting result of the ruling was a DOT/FAA opinion that if an
airport can document congestion delays during certain times, it can then
implement a congestion surcharge to ALL arrivals during these times. (There
are a few permitted exemptions, but scheduled airline is not one of them.)
However, it can only do so during the hours that the documented congestion
exists. It can't, as Massport tried to do, apply the surcharge 27-7.
Currently, I am aware of JFK, EWR, and LGA using a congestion time
surcharge.
From the Federal Reserve Bank of Boston Regional Review, Winter 1997:
"Logan's landing fees, like those of virtually all U.S. airports, do
not reflect congestion. Fees are based instead on weight. So a typical
wide-body jet pays roughly $800 while the smallest plane, which causes as
much congestion, pays $25.
In 1988, Massport did try a fee scheme that combined aircraft weight with
an additional fee per landing. Flights by smaller planes became relatively
more expensive, and their use of Logan dropped substantially, although that
reduction was also affected by industry consolidations. The scheme ended
after it was judged discriminatory against small planes by the U.S.
Department of Transportation, which noted that small aircraft paid higher
prices even at hours when there was ample runway capacity. At the same
time, the agency ruling opened the door to peak-load pricing, noting that
"it may be appropriate to raise fees in order to invoke market responses
during periods when the airport is congested.""
Another reference you may find interesting is the FAA's letter to
Massport of June 10, 2004 available at:
http://web.nbaa.org/public/ops/airpo...er20040610.pdf
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old May 12th 05, 03:46 AM
Jose
Which airport [was rebuked by the FAA for discriminatory fees]?
A few comments from airnav about Logan (BOS):
Nov 2004: $391 in fees for an overnight stay. $160 ramp, $42 GPU, $48
security fee, $52 parking, $22 Mass. GA fee and and extra $70 worth of
something-or-other fees. [note - unspecified aircraft type - GPU hints
it might be a jet?]
Nov 2003: $43.30 security fee, $27.50 landing fee, $22 MA General
Aviation fee (this is a new fee at KBOS), $27.50 parking fee, and $22
handling fee. [a three hour stay, unspecified type]
I don't know what this "security fee" is but in 2003 there were noises
that if you made noise you could get it waived.
So, I guess they found another way to discriminate. Hire Signature to
do it for you.
Jose
Money: what you need when you run out of brains.
Old May 12th 05, 07:17 AM
Marty Shapiro
Jose wrote in
it might be a jet?]
do it for you.
Jose
That's exactly how the airport authorities game the system! DOT/FAA
only ensure just and non-discriminatory landing fees. They do NOT require
an airport to provide a public ramp. So, the airport wanting to keep GA
out simply charges an outrageous rental to the FBO(s), who then pass on the
high costs to transient aircraft. I've sometimes wonder what percentage of
Signature's bad reputation with pilots of light GA aircraft should really
fall on the airport.
Marty Shapiro
Silicon Rallye Inc.
User Fees Dude Owning 36 March 19th 05 05:57 PM
NAA Fees to the US Team Doug Jacobs Soaring 2 October 29th 04 01:09 AM
LXE installation XP, strict user permissions. Hannes Soaring 0 March 21st 04 11:15 PM
The Irony of Boeing/Jeppesen Being Charged User Fees! Larry Dighera Piloting 9 January 23rd 04 12:23 PM
Angel Flight pilots: Ever have an FBO refuse to wave landing fees? Peter R. Piloting 11 August 2nd 03 01:20 AM
