2-stroke diesel is the (near) future?
Old May 13th 05, 06:17 PM
Sport Pilot
Don Stauffer wrote:
Don Stauffer wrote:
A 4-stroke diesel is still an Otto engine. An Otto cycle engine is
one
with four strokes, intake, compression, power, and exhaust.
Doesn't
care whether SI or CI.
Whoops
Before everyone jumps on me, I left off an important qualification.
I
was specifically talking about cars, airplanes and highway trucks.
Large Diesels, (stationary, large ship, etc) do run a different
cycle-
the true Diesel cycle.
However, even the true Diesel cycle of larger engines is not the true
cycle Diesel really wanted. He couldn't develop the true cycle he
wanted (constant enthalpy), and a large Diesel comes somewhat close.
A
high speed (vehicle) engine doesn't even come close with even today's
technology. It is pretty close to an Otto cycle, though still not
exactly. Otto cycle has infinitesmal fraction of cycle for ignition
and
burn, while even a high speed Diesel (and even the SI engine) still
ignites and burns over a finite angle of crank rotation. Still, the
result, as I say is MUCH closer to Otto than the cycle Rudy had
intended. Still makes a good engine, however :-)
You can only get so much speed when you inject the fuel through the
combustion or expansion cycle. High speed diesels get more speed by
injecting more of the fuel early. But an aircraft engine doesn't need
to turn more than 2500 RPM so we should be able to get the benifit of
the longer burn time.
Old May 14th 05, 03:54 PM
Don Stauffer
True, but even 2500 rpm is a high speed Diesel. When we speak of low
speed Diesels, those are like the big ship and stationary engines that
run maybe 800 rpm max.
Old May 15th 05, 09:17 PM
Thomas Tornblom
Don Stauffer writes:
I once had the opportunity to visit the engine room of one of the big
ferries cruising between Sweden and Finland. It had four engines and
two props.
The idle speed was 100 rpm and full speed was 150 rpm.
I could not hear any difference between 100 and 150 rpms. But then I
never knew what noise came from the propulsion engines. There were a
lot of other helper engines making a lot of noise.
The props were geared 2:1, so they did 75 rpms at full speed.
Thomas
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
