![]() Don Stauffer wrote: Don Stauffer wrote: A 4-stroke diesel is still an Otto engine. An Otto cycle engine is one with four strokes, intake, compression, power, and exhaust. Doesn't care whether SI or CI. Whoops Before everyone jumps on me, I left off an important qualification. I was specifically talking about cars, airplanes and highway trucks. Large Diesels, (stationary, large ship, etc) do run a different cycle- the true Diesel cycle. However, even the true Diesel cycle of larger engines is not the true cycle Diesel really wanted. He couldn't develop the true cycle he wanted (constant enthalpy), and a large Diesel comes somewhat close. A high speed (vehicle) engine doesn't even come close with even today's technology. It is pretty close to an Otto cycle, though still not exactly. Otto cycle has infinitesmal fraction of cycle for ignition and burn, while even a high speed Diesel (and even the SI engine) still ignites and burns over a finite angle of crank rotation. Still, the result, as I say is MUCH closer to Otto than the cycle Rudy had intended. Still makes a good engine, however :-) You can only get so much speed when you inject the fuel through the combustion or expansion cycle. High speed diesels get more speed by injecting more of the fuel early. But an aircraft engine doesn't need to turn more than 2500 RPM so we should be able to get the benifit of the longer burn time. |
Sport Pilot wrote:
You can only get so much speed when you inject the fuel through the combustion or expansion cycle. High speed diesels get more speed by injecting more of the fuel early. But an aircraft engine doesn't need to turn more than 2500 RPM so we should be able to get the benifit of the longer burn time. True, but even 2500 rpm is a high speed Diesel. When we speak of low speed Diesels, those are like the big ship and stationary engines that run maybe 800 rpm max. |
Don Stauffer writes:
Sport Pilot wrote: You can only get so much speed when you inject the fuel through the combustion or expansion cycle. High speed diesels get more speed by injecting more of the fuel early. But an aircraft engine doesn't need to turn more than 2500 RPM so we should be able to get the benifit of the longer burn time. True, but even 2500 rpm is a high speed Diesel. When we speak of low speed Diesels, those are like the big ship and stationary engines that run maybe 800 rpm max. I once had the opportunity to visit the engine room of one of the big ferries cruising between Sweden and Finland. It had four engines and two props. The idle speed was 100 rpm and full speed was 150 rpm. I could not hear any difference between 100 and 150 rpms. But then I never knew what noise came from the propulsion engines. There were a lot of other helper engines making a lot of noise. The props were geared 2:1, so they did 75 rpms at full speed. Thomas |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
