Gary Drescher wrote:
So even though the President has to obey the judiciary, the NTSB doesn't? Is there a documented example of such defiance by the NTSB? Tons. The procedure if you are charged with a violation is that your case is heard first by an FAA board. If you object to their ruling, you can appeal it to a law judge. If either you or the FAA objects to the judge's ruling, you or they can appeal to the 7 member National Transportation Safety Board. Their ruling is final -- there is no appeal. Remember that you have not been charged with a crime. You have been charged with violation of the FAA rules instituted for the safety of the American public. The judicial branch does not have the final say. The NTSB is infamous in pilot circles for reversing the judges' decisions and reinstituting (at least in part) the original penalty applied by the FAA. George Patterson "Naked" means you ain't got no clothes on; "nekkid" means you ain't got no clothes on - and are up to somethin'. |
"George Patterson" wrote in message
news:E5che.41$Vu6.14@trndny03... Gary Drescher wrote: So even though the President has to obey the judiciary, the NTSB doesn't? Is there a documented example of such defiance by the NTSB? Tons. Even one will suffice. But can you cite any documentation, please? If either you or the FAA objects to the judge's ruling, you or they can appeal to the 7 member National Transportation Safety Board. Their ruling is final -- there is no appeal. What leads you to believe that? Thanks, Gary |
Even one will suffice. But can you cite any documentation, please? A Ramp Check (adopted from May 1996 AOPA Pilot) A legal decision of the National Transportation Safety Board provides a look at an actual FAA ramp check. The case shows us how a few technical violations, coupled with some prior antagonism, can escalate into a serious problem for the pilot of the flight being checked - in this case, a 90-day suspension of the pilot's ATP certificate. The Board's decision leaves the pilot's responsibilities in a ramp inspection cloudy. It was the day before Thanksgiving, 1993. The pilot was captain of a Learjet carrying some cargo from Sparta, Tennessee, to Monroe, Michigan. It was a commercial flight operated under Part 135 of the Federal Aviation Regulations. The flight made a refueling stop at Smyrna, Tennessee — which is only some 45 miles from Sparta — because of the low price of fuel at the airport there. The pilot had called ahead to arrange with the fixed base operator at Smyrna for a "quick turnaround." The stop was to take no more than 10 minutes. As it turned out, it took much longer, and the second stage of the flight was eventually canceled. At the time that the Lear landed at Smyrna, there were two inspectors from the Nashville Flight Standards District Office who were at the airport to talk to a woman who owned a flight school that was having some problems. She wasn't available, and as they saw the Lear taxi in, the inspectors decided to do a ramp check on the Lear. As the airplane parked, they approached it, and at least one of them presented his credentials to the pilot, announcing the ramp inspection. According to the captain, one of the inspectors refused to present his credentials. There had been some prior antagonism between the inspectors and the company operating the flight, and some litigation in federal court, but the decision gives no details. It was an unusually thorough inspection. At the request of the inspectors, the pilots presented their pilot and medical certificates, the aircraft registration and airworthiness certificates, the operations manual and the operations specification of the FAR Part 135 operator, the minimum equipment list, the load manifests, and the shipping papers for the cargo being carried. According to the evidence, one of the inspectors was going through the operations manuals page by page. The inspectors were allowed into the aircraft, and they even rummaged through the cargo. The pilots provided everything the inspectors asked for, though things got a bit testy as the inspectors seemed to be taking their time in an obviously time-critical situation, and the captain overheard some negative comments. The estimates of how long the inspection took ranged from 40 to 50 minutes to as long as an hour. After that thorough review of the documents, the inspectors found two problems that I call "technical." They found errors in the load manifest for the flight from Sparta to Smyrna, and they found that an IFR flight plan had not been filed for that flight. Even though, on the flight to Smyrna, the Lear was more than 3,000 pounds under allowable gross weight and well within center-of-gravity limits, the load manifest was technically in error. The copilot erroneously used the standard average weights of 165 pounds for each of the crewmembers (as allowed on a larger airplane he had been flying), for a total of 330 pounds, instead of their actual weights which totalled about 490 pounds. Also, the weight of the cargo was listed as 330 pounds instead of the actual weight of 520 pounds. The weight of the cargo listed on the shipping papers was in kilograms, and the 330-pound figure used by the crew was given to them by the person who delivered cargo to the airplane - which was the usual practice. In any event, technically, the load manifest was wrong. As for the absence of an IFR flight plan, the operations specification did require that turbojet airplane flights conducted under Part 135 must be operated under IFR though there seemed to be some confusion in the ops specs. However, the flight, as short as it was, was in constant communication with air traffic control during the entire flight, under radar contact, utilizing flight following, but, technically, not IFR. The problems really became exacerbated when one of the inspectors wanted to check the fuel load for the next leg of the flight. The drivers of the FBO's fuel trucks, under instructions to top off the tip tanks, refueled the airplane. The Lear has a fuselage tank — a "trunk" tank, and filling the tip tanks did not necessarily mean that the fuselage tank would also be full. To determine the amount of fuel in the fuselage tank, the inspector asked the pilot to turn on the aircraft's Master switch so that the fuel gauge could be read. The pilot refused, telling the inspector that he was in a hurry. The pilot later testified to his understanding that while he was under obligation to allow access to the airplane and the paperwork, he was not under obligation to do anything like turning on the Master switch. He had not been asked to do anything like that in previous ramp checks. And, his understanding had been confirmed in conversations that he had with other pilots and FAA inspectors. The inspector then demanded an en route inspection, presumably to be on board when the Master switch had to be turned on and the gauge could be read. The pilot, now with the added fuel, refused to conduct the flight with the inspector on board, saying that the aircraft would be over gross weight if it took off with the inspector on board. The inspector suggested that the pilot burn off 200 pounds of fuel before takeoff. The pilot didn't consider that suggestion viable and walked away from the aircraft. The flight was canceled. Another jet was dispatched to complete the flight. The crew repositioned the Lear to another airport in Tennessee and then got in their cars to try to make it home for Thanksgiving. The inspectors sent out three letters, to the pilots and the operator, notifying them that this incident was under investigation. When the operator received the letter, the operator sent a fax to the pilots, who were on a trip, grounding them and telling them to report to Houston for an employment evaluation interview and retraining. Company officials believed that if they were tough on the pilots, that would satisfy the FAA and the matter would be dropped. That was not to be, at least not for the captain. The decision does not tell us what action was taken against the company or the copilot. Ultimately, the FAA issued an order suspending the captain's ATP certificate for 90 days, charging him with several regulatory violations, including preparing an inaccurate load manifest, failing to operate the flight IFR as required by the operations specifications, and failing to allow the inspectors to conduct the ramp inspection. The FAA also charged the pilot with carelessly endangering life or property. The captain appealed the suspension to the NTSB. A hearing was held before an administrative law judge, who affirmed the FAA in part and reduced the suspension to 45 days. While the judge found that the FAA request to turn on the Master switch was reasonable, he also found that the captain's refusal was also reasonable. He did not think it reasonable for the FAA to expect the captain to burn off 200 pounds of fuel in order to accommodate the en route inspection. He threw out the two charges related to interfering with the ramp inspection and reduced the suspension. Both the captain and the FAA further appealed the law judge's decision to the full five-member Board. The full Board granted the FAA's appeal and reinstated the 90-day suspension. It denied the captain's appeal. The full Board agreed with the FAA that by refusing to turn on the Master switch, the pilot prevented the inspectors from completing the inspection. The Board rejected the pilot's argument that he was not required by regulation to assist the FAA in its inspection. The Board also said that the expense to the carrier of burning off 200 pounds of fuel was "minimal." The fact that "both sides may have become impatient with one another" does not warrant a reduction of the sanction. It affirmed the FAA position that the violations "potentially" endangered others. It reinstated the 90-day suspension. George Patterson "Naked" means you ain't got no clothes on; "nekkid" means you ain't got no clothes on - and are up to somethin'. |
news:l8dhe.75$4d6.71@trndny04... Gary Drescher wrote: Even one will suffice. But can you cite any documentation, please? A Ramp Check (adopted from May 1996 AOPA Pilot) ... Thanks. But there's no assertion there that the full Board's decision is not subject to judicial review (let alone any *evidence* for such an assertion). Think about it--how could the NTSB possibly have acquired such an astonishing power? Neither Congress nor the President has such a power, nor the ability to confer such a power on any other person or group. By the way, here's what the NTSB itself says about it: "If either the FAA or the airman is dissatisfied with the judge's decision, a further appeal may be taken to the NTSB's full five-member Board. If the airman or FAA is dissatisfied with the full Board's order, either may obtain judicial review in a federal appeals court. However, the FAA can only appeal the Board's order in cases that it determines may have a significant adverse impact on the implementation of the Federal Aviation Act." (http://www.ntsb.gov/abt_ntsb/olj.htm) --Gary |
George Patterson wrote:
As for the absence of an IFR flight plan, the operations specification did require that turbojet airplane flights conducted under Part 135 must be operated under IFR though there seemed to be some confusion in the ops specs. However, the flight, as short as it was, was in constant communication with air traffic control during the entire flight, under radar contact, utilizing flight following, but, technically, not IFR. Not filing IFR, as required, is not the same as getting lost. Apples and oranges. This is would be an intentional violation, IMO. |
![]() If either you or the FAA objects to the judge's ruling, you or they can appeal to the 7 member National Transportation Safety Board. Their ruling is final -- there is no appeal. I thought you could take it to Federal Appeals Court... http://www.kscourts.org/ca10/cases/2001/09/00-9500.htm ....and thence to the Supreme Court, although I don't think SCOTUS has ever accepted such a case... |
"George Patterson" wrote:
... If either you or the FAA objects to the judge's ruling, you or they can appeal to the 7 member National Transportation Safety Board. Their ruling is final -- there is no appeal. Yes there is -- to the Circuit Courts of Appeal, and to the Supreme Court. Fred F. |
Remember that you have not been charged with a crime. You have been charged with violation of the FAA rules instituted for the safety of the American public. The judicial branch does not have the final say. The judicial branch has the final say in both civil and criminal matters. You could appeal your case all the way up to the Supreme Court, if you wanted to pay for the lawyers all the way up. (There's no guarantee that any of the courts would hear your case, but even their decision to hear your case or not is a form of judicial review.) Here is a case where the U.S. Court of Appeals overrules the judgment of the FAA and the NTSB. Especially note this paragraph: --- The FAA and the NTSB argue that this Court does not have jurisdiction to hear Reder's appeal. We disagree. Judicial review of FAA or NTSB orders is contemplated by 49 U.S.C. 44709(f) (1994) of the Federal Aviation Act's Safety Regulations. Section 44709(f) directs that orders of the NTSB or the FAA be reviewed pursuant to 49 U.S.C. 46110 (1994). --- http://caselaw.lp.findlaw.com/cgi-bi...ase&no=962438p Charles. -N8385U |
"Charles O'Rourke" -net wrote in message
news:lUghe.13514$iU.12603@lakeread05... The judicial branch has the final say in both civil and criminal matters. You could appeal your case all the way up to the Supreme Court, if you wanted to pay for the lawyers all the way up. (There's no guarantee that any of the courts would hear your case, but even their decision to hear your case or not is a form of judicial review.) Yup. What concerns me most about these threads is that so many pilots are willing to believe--on the basis of mere rumors and urban legends--that we actually live under a totalitarian system in which a minor administrative authority routinely and openly operates without even nominal regard for due process, and is so powerful as to be invulnerable to the judiciary! And these pilots are willing to acquiesce to this (fortunately imaginary) totalitarianism without mounting significant resistance. Their willingness serves as an unwitting invitation to actually bring about such a state of affairs. In other walks of life, of course, the Patriot Act, and US practices of disappearance and torture, pose far more dire threats to due process and other Constitutional and international human-rights guarantees. But at least there *is* resistance being mounted--politically, and through litigation by groups such as the ACLU. And there is no doubt that the judiciary has the final say in these matters, although they have limited their intervention so far. --Gary |
"Gary Drescher" wrote in message
... What concerns me most about these threads is that so many pilots are willing to believe--on the basis of mere rumors and urban legends--that we actually live under a totalitarian system in which a minor administrative authority routinely and openly operates without even nominal regard for due process, and is so powerful as to be invulnerable to the judiciary! IMHO, part of the problem is that the "minor administrative authority" does "routinely and openly operate without even nominal regard for due process". That is, they act as though there is no judicial review, and are not challenged on those actions nearly often enough. They may not actually be "so powerful as to be invulnerable to the judiciary", but they sure act like it on a regular basis. Perhaps another part of the problem is that the judiciary so infrequently chooses to review decisions made by the "minor administrative authority". When an administration is permitted to interpret their own rules as they see fit, and the judiciary makes the assumption that the actions of the administration are entirely appropriate for their charter to ensure aviation safety, without regard for their charter to promote aviation, it's easy to see how some folks might get the wrong idea. Pete |
NASA form use for someone else's event | Andrew Gideon | Piloting | 4 | March 31st 05 01:50 PM |
First NASA form filed | Paul Folbrecht | Piloting | 38 | August 24th 04 05:39 PM |
Runway Incursion and NASA form | Koopas Ly | Piloting | 16 | November 12th 03 01:37 AM |
Runway Incursion and NASA form | steve mew | Piloting | 0 | November 10th 03 05:37 AM |
Moving violation..NASA form? | Nasir | Piloting | 47 | November 5th 03 07:56 PM |
