2-stroke diesel is the (near) future?
Old May 14th 05, 12:53 AM
Luke Scharf
Steve wrote:
But there are more and more small diesels that run just as fast as
gasoline engines. There's no fundamental limit thats any different than
a gasoline engine, really, but up until now there's not been a demand
for high-RPM diesels.
When I was reading about the Volkswagen TDI engine, I vaguely remember
coming across someone who said that the redline of that engine was set
by the speed which which the burning fuel expanded.
Sounds rather fundamental to me - but, then again, I'm a computer guy.
-Luke
Old May 15th 05, 09:11 PM
Thomas Tornblom
Luke Scharf writes:
than a gasoline engine, really, but up until now there's not been a
demand for high-RPM diesels.
My '01 180 bhp Audi 2.5 tdi V6 has a redline of 4500 rpm.
-Luke
Thomas
Old May 16th 05, 04:44 AM
Luke Scharf
Thomas Tornblom wrote:
Luke Scharf writes:
That's about where the one on the Jetta was -- right around 4500 rpm.
The displacement on the Jetta is only 1.6 liters, though... I wonder
what dimensions are similar to make the smaller engine redline at the
same speed?
When I got to the redline, the engine seemed to politely refuse to go
any faster. Not like the screaming tantrum I'm used to from my
run-of-the-mill gas engines as I open the throttle.
I dig diesels. :-)
-Luke
Old May 16th 05, 05:39 PM
Steve
-Luke
In almost ALL real-world engines, the actual limit is set by the point
at which some mechanical component would fail. The engine's torque *may*
drop off well before the mechanical failure point if it can't ingest
enough fuel or air at high speed. In the case of a diesel, you can
pretty much increase the burn rate to as high as the mechanical parts
can tolerate by increasing turbocharger boost (and injection rate to
match). Since detonation isn't possible (no fuel exists in the cylinder
until combustion is supposed to begin anyway) the only limits to boost
pressure are mechanical in nature. In practical terms, no one really
wants or needs a 9000 RPM diesel, though.
Old May 16th 05, 07:01 PM
Sport Pilot
a
remember
set
guy.
-Luke
point
*may*
cylinder
boost
Diesel fuel is not conducive to high speed running. Nor is a long
injection period through much of the expansion phase. Yes you can
boost the turbocharger and the other things, but an Otto cycle engine
will respond with even higher speeds. Parts failure from speed is not
a problem with diesel engines, the rotating parts have to be bigger
than an otto engine because of the higher compression, yet the otto
engine will turn higer RPM's with smaller parts.
Old May 16th 05, 09:08 PM
Steve
All of the above is true in the common practice of diesel design, but
none of it is necessarily true. There is nothing FUNDAMENTAL that limits
a diesel to low-RPM designs only. One can build a screaming high-RPM
diesel with light-weight rotating parts, but one would have to ask
"why?" Gasoline engines are made high-revving in order to increase power
output from a small package, but diesels can develop a lot more low-RPM
torque through high boost because they don't detonate when "lugged," so
there's no NEED to make them scream. If you need more power, don't spin
them faster, just boost them harder. High RPM is an aggravation, not an
advantage (no matter what Honda VTEC drivers think...).
Old May 16th 05, 09:30 PM
Sport Pilot
engine
not
limits
power
low-RPM
so
spin
an
Actually diesels don't really deliver that much torque at similar
speeds. Ok they do but only because the valving is timed for the
slower speeds. Many gasoline tractor engines will diliver similar
torque, but with a higher fuel consumption due to the lower compression
ratio. Diesel fuel burns slower and will knock when the injection
timing is shortened to allow higher speeds.
Old May 16th 05, 10:45 PM
Steve
engine
not
limits
power
low-RPM
so
spin
an
ratio.
It depends on what you're comparing to. A lot of tractors use
normally-aspirated indirect-injection diesels, which are no comparison
to a turbocharged diesel. Or to a good normally-asipirated gasoline
engine, except in terms of longevity. Gasoline engines are hard to beat
for the *width* of their torque curve, but modern turbo-diesels do a
good job against them, and do so with better efficiency.
Higher speed requires more than just rapid injection, it also demands
higher boost pressure, which causes the fuel to burn faster without any
knock-like phenomenon. All serious diesels are turbocharged for that
reason (as well as others), and normally-aspirated diesels are limited
to very small power outputs and relatively low efficiency. You can only
get so much combustion chamber pressure through the compression ratio of
the engine- the rest has to come from forced induction. As someone
pointed out earlier, the VW TDI develops power up to 4500 RPM, which is
comparable to many gasoline engines, but it is able to do so only
because it is a turbo-diesel. As I said before, there's no reason that
building a 7000-RPM diesel isn't possible, but there's no REASON to
build one.
Old May 17th 05, 02:18 PM
Don Stauffer
I would assume that use of hydrogen as a fuel would allow very high rpm
in a Diesel.
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
