2-stroke diesel is the (near) future?
Old May 13th 05, 11:39 PM
Morgans
"Steve" wrote
As already stated, 2-stroke diesels really don't have a power-to-weight
advantage over 4-strokes. They still have to have a camshaft and
exhaust valves (they aren't like weed whacker engines, you know), so
they don't save that weight. Plus they have to have a blower for
scavenge air. The only area where they save weight is in that the
connecting rod and crank can be lighter, and that only helps offset the
added weight of the blower.
How about the fact that they have power pulses in each revolution? They
could possibly have half the displacement, and still get the same power, (or
close to it) with less weight than the double displacement 4 cycle. Yes,
the blower weight is added, but it is nice to make good power, way up there.
Jim in NC
Old May 16th 05, 05:35 PM
Steve
The blower also takes away a significant chunk of crankshaft power. The
blower has to do the same net work as those "non power" strokes in a
4-cycle diesel because its doing the same job- expelling burnt mixture
and bringing in fresh air. You can't get something for nothing.
This is all old-hat. 2-stroke diesels have been in widespread use since
Winton developed the basic foundation for what became both the EMD and
Detroit Diesel 2-stroke engine architecture back in the 1920s. 2-strokes
became very simple to service and reliable, but they rarely won on
either fuel efficiency or total power output per unit weight. That's why
you find 2-strokes in locomotives and ships where weight doesn't matter
(or is a benefit), but they all but disappeared from on-road
applications by the end of the 1970s and DID completely disappear by the
turn of the century.
Old May 16th 05, 06:52 PM
Sport Pilot
Steve wrote:
Morgans wrote:
power-to-weight
so
They
power, (or
Yes,
up there.
The
mixture
since
and
2-strokes
why
matter
I would have agreed at the start of this thread, but the two stroke
desiel does not have to be the same as the old locomotive desiels. The
blower is not needed if the crankcase is used to pump fuel/air mixture.
Old May 16th 05, 09:05 PM
Steve
Sport Pilot wrote:
Steve wrote:
Morgans wrote:
power-to-weight
so
They
power, (or
Yes,
up there.
The
mixture
since
and
2-strokes
why
matter
You're describing a weed-whacker engine, not a 2-stroke Diesel. Good for
cheap manufacture and relatively light total weight, but at the expense
of a very narrow power band, terrible efficiency, terrible emissions,
and except at the peak of the power band, terrible power/weight ratio in
spite of being lightweight.
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
