Jim Weir: RST-442 intercom good
Old May 14th 05, 03:03 PM
Leo
Default Jim Weir: RST-442 intercom good
Jim and others interested,
I previously said that normal voice into the mikes on the headsets I
installed in my new homebuilt wouldn't easily break the squelch of the newly
built RST-442 Intercom I had also installed. Yesterday a friend used his
Sigtronics headset for the flight and the squelch was opened instantly. So
the cause of the problem was the inadequate output of the electret
microphones on the low cost headsets I had installed.
Thanks for a good product.
Leo
Old May 14th 05, 03:32 PM
RST Engineering
It usta was be that headsets had a "mic level" control on them so that you
could adjust the output of the microphone on a headset to be somewhat
standard across all makes and models of headset. It could compensate for
the fact that your particular voice was above or below a "normal" level.
Somebody somewhere decided that it would save a dime a headset to eliminate
this feature and we have all been suffering since. If we design an intercom
for a "normal" voice/headset level and then a particular headset is too LOW,
we have volume and squelch problems. If it is too HIGH then it distorts on
voice peaks. It really cobs up the works.
Glad you have found what the "problem" was.
"Leo" LeoPowningatYahoo.com wrote in message
newly built RST-442 Intercom I had also installed. Yesterday a friend
used his Sigtronics headset for the flight and the squelch was opened
instantly. So the cause of the problem was the inadequate output of the
electret microphones on the low cost headsets I had installed.
Leo
Old May 15th 05, 03:58 AM
Morgans
"RST Engineering" wrote in message
Would it be possible to make a widget to plug in, between the headset (mic)
and audio panel, that would provide an adjustment, to raise or lower the mic
output? Would you be interested in making it a Kitplanes column? (or other
vehicle to bring it to the public)
Jim in NC
Old May 15th 05, 07:44 AM
RST Engineering
If you bias the microphone with a 470 ohm resistor from any voltage from 8
to 20 volts, you should get an AC voltage at the bias point of half a volt
peak to peak with a "normal" voice. This is a field measurement, and not
the exact RTCA specification, which goes on to specify a lot of other crap
that is pretty meaningless.
"Normal" is not defined.
"karel" wrote in message
Jim,
While we're on this subject, what are the specs for a "standard"
microphone input (i.e. from aheadset) on an audio panel?
I know I could google it out or search your website,
but couldn't resist asking as the subject floated along...
TIA!
KA
HAVE YOU HEARD THE GOOD NEWS! [email protected] Soaring 0 January 26th 05 07:08 PM
Four States and the Grand Canyon Mary Daniel or David Grah Soaring 6 December 6th 04 10:36 AM
intercom question GE Owning 4 July 14th 04 05:40 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Piloting 0 December 11th 03 09:42 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
