2-stroke diesel is the (near) future?
Old May 14th 05, 03:52 PM
Don Stauffer
Sport Pilot wrote:
The Diesel is not an Otto cycle it is a completly differant cycle. The
Diesel is a constant pressure cycle where the presure is constant
through the expansion phase.
I wouldn't say the ENTIRE expansion phase. That would not be that great
for efficiency- sort of like a steam engine running with no cutoff. And
if one injects fuel into the cylinder at the instant just before BDC,
that fuel would be pretty much wasted. I was under the impression that
the cycle would look something like the steam (Rankine) cycle in that
the way Diesel envisoned it it would be either constant enthalpy or
constant pressure of part of the expansion phase, adiabatic during the
rest. The point where it changed would correspond to what would be the
throttle opening on a steam or SI engine. At full "throttle" the
changeover would be late in stroke, light load early in stroke.
Old May 15th 05, 03:52 AM
Sport Pilot
Don Stauffer wrote:
The
great
And
that
Where did I say the entire expansion phase? Where did I say there was
a perfect Diesel cycle?
Old May 16th 05, 05:46 PM
Steve
True, although diesel engine manufacturers of late have discovered that
they can do things like reduce the injection flow rate instead of just
reducing injection duration. That has the nice side-effect of REALLY
quieting diesel "rattle" at light throttle openings, as most clearly
evidenced by the current Cummins diesel in the Dodge Ram. The flow
rate/duration combination can be played with to do really neat things to
the torque curve also. The stumbling block that prevented this for many,
many years was the camshaft-driven fuel injection pump, and its limited
ability to vary injection timing and volume. Once the move was made to
computer control and use of electronically controlled engine
oil-pressure activated unit injectors, a lot of possibilities opened up.
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
