Circle to land question
Old May 16th 05, 04:08 PM
Gene Whitt
Y'All,
Here are some thoughts that I have not yet posted to my web site.
Would appreciate any additions.
Gene Whitt
Flying in Circles IFR
---Circling approaches are an option to be avoided in times of reduced
visibility
---Circling requires that you have the runway in sight at all times
---You cannot leave the circling MDA unless able to descend to the runway
---You must choose the circle before descending below its MDA
---Circling at night, in low visibility and exposed to disorientation is a
lost poker hand
---The notes restricting just where circling is allowed is usually a clue
---Don't ask for a circling approach where ceilings are not well above
circling minimums
---By keeping your distance from the airport until turning final you avoid 'killer'
bank angles
---Being IFR in VFR conditions at an airport does NOT give you any special
'rights'
---Go missed if you lose visual of the runway
Old May 16th 05, 04:37 PM
Dave Butler
Gene Whitt wrote:
Y'All,
I'd add a note that although it is often recommended that one not descend below
MDA until you are aligned on the final, there are some circling approaches where
following this policy will cause you to miss, since at the minimum permissible
visibility, you will be too high to descend to the runway.
Gene Whitt
visibility
"the" - "to" ? You must choose to circle... ?
lost poker hand
circling minimums
bank angles
'rights'
Old May 16th 05, 06:21 PM
Ron Rosenfeld
Gene,
Although I agree that circling approaches at minimums are arguably one of
the most dangerous things a GA IFR pilot can do, I feel that with proper
training, briefing and precautions, they can be safely accomplished.
It gets into the area of trying to teach judgement.
--ron
On Mon, 16 May 2005 15:08:09 GMT, "Gene Whitt"
Y'All,
Gene Whitt
visibility
Circling approaches are an option to be approached with extreme caution in
times of reduced visibility
USING NORMAL MANEUVERS AND AT A NORMAL RATE OF SPEED
POTENTIALLY LOSING POKER HAND
circling minimums
UNLESS YOU ARE CONFIDENT OF YOUR ABILITIES; AND CURRENT WITH THE PROCEDURE.
bank angles
'rights'
Add emphasis to this one (above)
AT ANY TIME, EVEN IF JUST BRIEFLY.
Old May 16th 05, 06:23 PM
Ron Rosenfeld
Y'All,
Gene Whitt
Oh, and I'd add:
If you don't have the runway in sight prior to the MDA, you may NOT be able
to make a successful landing using normal maneuvers (a requirement to
operate below the MDA).
Old May 16th 05, 06:28 PM
Dave Butler
I'm sure Gene understands what you are saying, but for my benefit, could you
elaborate a little on this statement? Why is this true?
Thanks.
Dave
Old May 16th 05, 09:32 PM
Stan Gosnell
Dave Butler wrote in news:1116264343.869268@sj-nntpcache-5:
be able to make a successful landing using normal maneuvers (a
requirement to operate below the MDA).
could you elaborate a little on this statement? Why is this true?
Cloud bases are seldom perfectly level. They are lower in some places
than in others. If you get the airport in sight right at MDA, then it's
likely that there will be areas where the cloud bases will be below MDA,
and you'll probably fly through them as you circle.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old May 16th 05, 09:58 PM
Dave Butler
OK, sure, thanks, but if Ron meant that, wouldn't he have said "...you're likely
to have to go missed... " instead of all that stuff about normal maneuvers? I'd
still like to hear Ron's answer.
Dave
  #28
Old May 16th 05, 10:36 PM
Roy Smith
Clouds can do some weird **** (especially near bodies of water). I
once flew into UUU (Newport, RI) for a practice approach. The plan
was a low approach and go missed. The airport is near the coastline,
and the approach is from over land towards the water. Inbound to the
airport, I was in decent visibility and little bits of scattered scud
here and there. What I didn't realize was that there was a low
overcast layer on the water side, that ended just about at the
airport.
I reached the MAP, had a perfect view of the runway, started my climb,
and almost immediately found myself in solid IMC. Had I been doing a
circling approach, I could have easily found myself suddenly in cloud
while circling below the MDA.
  #29
Old May 17th 05, 12:35 AM
Ron Rosenfeld
Thanks.
Dave
I miswrote a bit. In addition to what others have written, what I really
meant to write was that "if you don't have the airport in sight prior to
the MAP (missed approach point) ..."
And the reason for that has to do with geometry. The MAP may be too close
and to allow for normal maneuvers to land. (And using normal maneuvers is
a requirement of 91.175)
Sorry about the confusion.
  #30
Old May 17th 05, 01:32 AM
A Lieberman
On Mon, 16 May 2005 15:08:09 GMT, Gene Whitt wrote:
Hi Gene,
First and foremost, thanks for hosting your awesome website! Some of my
comments in my "newbie" sense of the IFR world.
visibility
This would be tough to avoid at an airport like mine. Maybe rephrase:
IF POSSIBLE Circling approaches are an option to be avoided in times of
reduced visibility. Precision approaches should be the preferred choice if
available.
Can you clear this statement up? I am not sure I understand it.
lost poker hand
I would rephrase the last part ....a potentially loosing poker hand.
bank angles
You may want to add to this statement, keep in mind winds aloft direction
may push you closer to the airport then you intend.
Allen
Confused about great circle navigation xerj Piloting 7 July 10th 04 05:38 PM
R in a Circle (Airport Surveillance Radar) on VFR charts Jeff Saylor Piloting 66 May 12th 04 04:05 PM
Great circle formulae, True cource and actual heading Sims Piloting 27 October 11th 03 01:55 PM
Defensive circle Dave Eadsforth Military Aviation 23 October 9th 03 06:13 PM
NACO charts - why have a reference circle? Bob Gardner Instrument Flight Rules 5 September 6th 03 01:15 PM
