Don Stauffer wrote:
I wouldn't say the ENTIRE expansion phase. That would not be that great for efficiency- sort of like a steam engine running with no cutoff. And if one injects fuel into the cylinder at the instant just before BDC, that fuel would be pretty much wasted. I was under the impression that the cycle would look something like the steam (Rankine) cycle in that the way Diesel envisoned it it would be either constant enthalpy or constant pressure of part of the expansion phase, adiabatic during the rest. The point where it changed would correspond to what would be the throttle opening on a steam or SI engine. At full "throttle" the changeover would be late in stroke, light load early in stroke. True, although diesel engine manufacturers of late have discovered that they can do things like reduce the injection flow rate instead of just reducing injection duration. That has the nice side-effect of REALLY quieting diesel "rattle" at light throttle openings, as most clearly evidenced by the current Cummins diesel in the Dodge Ram. The flow rate/duration combination can be played with to do really neat things to the torque curve also. The stumbling block that prevented this for many, many years was the camshaft-driven fuel injection pump, and its limited ability to vary injection timing and volume. Once the move was made to computer control and use of electronically controlled engine oil-pressure activated unit injectors, a lot of possibilities opened up. |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
