![]() Steve wrote: Morgans wrote: "Steve" wrote As already stated, 2-stroke diesels really don't have a power-to-weight advantage over 4-strokes. They still have to have a camshaft and exhaust valves (they aren't like weed whacker engines, you know), so they don't save that weight. Plus they have to have a blower for scavenge air. The only area where they save weight is in that the connecting rod and crank can be lighter, and that only helps offset the added weight of the blower. How about the fact that they have power pulses in each revolution? They could possibly have half the displacement, and still get the same power, (or close to it) with less weight than the double displacement 4 cycle. Yes, the blower weight is added, but it is nice to make good power, way up there. The blower also takes away a significant chunk of crankshaft power. The blower has to do the same net work as those "non power" strokes in a 4-cycle diesel because its doing the same job- expelling burnt mixture and bringing in fresh air. You can't get something for nothing. This is all old-hat. 2-stroke diesels have been in widespread use since Winton developed the basic foundation for what became both the EMD and Detroit Diesel 2-stroke engine architecture back in the 1920s. 2-strokes became very simple to service and reliable, but they rarely won on either fuel efficiency or total power output per unit weight. That's why you find 2-strokes in locomotives and ships where weight doesn't matter (or is a benefit), but they all but disappeared from on-road applications by the end of the 1970s and DID completely disappear by the turn of the century. I would have agreed at the start of this thread, but the two stroke desiel does not have to be the same as the old locomotive desiels. The blower is not needed if the crankcase is used to pump fuel/air mixture. |
Sport Pilot wrote:
Steve wrote: Morgans wrote: "Steve" wrote As already stated, 2-stroke diesels really don't have a power-to-weight advantage over 4-strokes. They still have to have a camshaft and exhaust valves (they aren't like weed whacker engines, you know), so they don't save that weight. Plus they have to have a blower for scavenge air. The only area where they save weight is in that the connecting rod and crank can be lighter, and that only helps offset the added weight of the blower. How about the fact that they have power pulses in each revolution? They could possibly have half the displacement, and still get the same power, (or close to it) with less weight than the double displacement 4 cycle. Yes, the blower weight is added, but it is nice to make good power, way up there. The blower also takes away a significant chunk of crankshaft power. The blower has to do the same net work as those "non power" strokes in a 4-cycle diesel because its doing the same job- expelling burnt mixture and bringing in fresh air. You can't get something for nothing. This is all old-hat. 2-stroke diesels have been in widespread use since Winton developed the basic foundation for what became both the EMD and Detroit Diesel 2-stroke engine architecture back in the 1920s. 2-strokes became very simple to service and reliable, but they rarely won on either fuel efficiency or total power output per unit weight. That's why you find 2-strokes in locomotives and ships where weight doesn't matter (or is a benefit), but they all but disappeared from on-road applications by the end of the 1970s and DID completely disappear by the turn of the century. I would have agreed at the start of this thread, but the two stroke desiel does not have to be the same as the old locomotive desiels. The blower is not needed if the crankcase is used to pump fuel/air mixture. You're describing a weed-whacker engine, not a 2-stroke Diesel. Good for cheap manufacture and relatively light total weight, but at the expense of a very narrow power band, terrible efficiency, terrible emissions, and except at the peak of the power band, terrible power/weight ratio in spite of being lightweight. |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
