Circle to land question
Old May 16th 05, 06:21 PM
Ron Rosenfeld
Gene,
Although I agree that circling approaches at minimums are arguably one of
the most dangerous things a GA IFR pilot can do, I feel that with proper
training, briefing and precautions, they can be safely accomplished.
It gets into the area of trying to teach judgement.
--ron
On Mon, 16 May 2005 15:08:09 GMT, "Gene Whitt"
Y'All,
Here are some thoughts that I have not yet posted to my web site.
Would appreciate any additions.
Gene Whitt
Flying in Circles IFR
---Circling approaches are an option to be avoided in times of reduced
visibility
Circling approaches are an option to be approached with extreme caution in
times of reduced visibility
---Circling requires that you have the runway in sight at all times
---You cannot leave the circling MDA unless able to descend to the runway
USING NORMAL MANEUVERS AND AT A NORMAL RATE OF SPEED
---You must choose the circle before descending below its MDA
---Circling at night, in low visibility and exposed to disorientation is a
POTENTIALLY LOSING POKER HAND
---The notes restricting just where circling is allowed is usually a clue
---Don't ask for a circling approach where ceilings are not well above
circling minimums
UNLESS YOU ARE CONFIDENT OF YOUR ABILITIES; AND CURRENT WITH THE PROCEDURE.
---By keeping your distance from the airport until turning final you avoid 'killer'
bank angles
---Being IFR in VFR conditions at an airport does NOT give you any special
'rights'
Add emphasis to this one (above)
---Go missed if you lose visual of the runway
AT ANY TIME, EVEN IF JUST BRIEFLY.
Confused about great circle navigation xerj Piloting 7 July 10th 04 05:38 PM
R in a Circle (Airport Surveillance Radar) on VFR charts Jeff Saylor Piloting 66 May 12th 04 04:05 PM
Great circle formulae, True cource and actual heading Sims Piloting 27 October 11th 03 01:55 PM
Defensive circle Dave Eadsforth Military Aviation 23 October 9th 03 06:13 PM
NACO charts - why have a reference circle? Bob Gardner Instrument Flight Rules 5 September 6th 03 01:15 PM
