RST Engineering wrote:
As to the AD on that switch, the owner can do the AD and sign it off. It is REALLY HARD to do. You fire the airplane up. You take it to the runup area. You turn the switch "off" with some reasonable force. If the engine stops, the AD passes. Ten seconds at the outside. And that is worth a $150 switch to get rid of the AD? $150 buys more beer than even JAY can drink in a day. While it's probably obvious to most people, I just want to make sure people understand this is to be done with the throttle at IDLE. Do not crank it up to $1700 and do something that might cycle both mags off and on again. You'll do what Rod Machado refers to as his student's click-click-click-BANG mag check. Not good for the exhaust. |
![]() Ron Natalie wrote: While it's probably obvious to most people, I just want to make sure people understand this is to be done with the throttle at IDLE. Do not crank it up to $1700 snip $1700? Freudian slip, or were you subliminally describing the end result of the explosion on the exhaust system? ;-) John Galban=====N4BQ (PA28-180) |
Airman Finds True Calling as Part of 'Best Force' | Otis Willie | Military Aviation | 0 | September 10th 04 11:18 PM |
BergFalke II/55 part. | Bruce Greeff | Soaring | 2 | May 12th 04 02:32 PM |
commercial privileges | Gary Drescher | Piloting | 32 | February 27th 04 02:42 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
Part 91 Commercial Glider Rides to be Outlawed? | Vaughn | Soaring | 9 | October 27th 03 09:26 PM |
