Avionics Cost Question
Old May 18th 05, 10:57 PM
Mike Rapoport
"Jay Honeck" wrote in message
news:L6Oie.5046$WG.3495@attbi_s22...
It costs next to nothing if you do it yourself and then have someone look
at it (or not). If you have the intercom that I think that you do: music
input (L) is pin 14 (and the barrel on the jack), (R) is pin T (and the
tip of the jack) and then ground the jack to wherever all the shields are
grounded. I think that I have the pins if you can tell me what length
wire you want, I will make you one.
Thanks, Mike. I'm hopelessly ignorant when it comes to this kind of
stuff, so bear with me...
When you talk about the "pins" I assume you mean the pins on the back of
the intercom, where the wiring harness plugs in? Isn't the harness
already plugged into pin 14 and pin T? How do I gain access to those
pins, so that I may connect another wire to them?
Or are these unused openings in the harness, and you're talking about
installing these pins INTO the wiring harness?
Either way, the wires wouldn't have to be more than 24 inches long.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Pins 14 and T are only used for an external music input which you don't seem
to have so the pins should be unused. If this is the case you will add a
wire (actually a two wire shielded cable) that will go from these pins (and
ground) to the jack where you will plug in your MP3 player. You might want
to go to PS Engineering's site and download the installation manual. If you
look at the wiring diagram, everything will be clear.
Mike
MU-2
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
avionics book reference and question mah Military Aviation 14 October 5th 03 01:17 AM
