Peter
Let me pose some what if's. I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. Big John `````````````````````````````````````````````````` ```````````````````````````````` On Mon, 16 May 2005 14:36:27 -0700, "Peter Duniho" wrote: "Robert M. Gary" wrote in message roups.com... [...] In the Mooney community is mostly agreed that a 201 (non turbo) will give you twice the cylinder life as a 231 (turbo). Other wear factors (heat, less air over the cylinders) are the same for turbo-norm vs. regular turbo. The only difference I can see is the "idiot" difference of accidently over boosting. Exactly what Mike said. Any kind of turbocharging will shorten the lifespan of a given engine. The whole point of a turbocharger, even turbo-normalizing, is to allow the engine to produce more power in certain situations than it otherwise would have. More power means more wear and tear. Turbo-normalizing isn't as hard on an engine as "non-normalized" turbocharging, but it still makes more power some of the time than the same engine without a turbocharger would (and on top of that, the increase in power is in situations when the air is less dense, making cooling more difficult...again, more heat, more wear). That time spent making more power results in more wear and tear. Pete |
The engine is going to be considerably hotter running at 65% at 15,000' than
at 5,000'. Mike MU-2 "Big John" wrote in message ... Peter Let me pose some what if's. I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. Big John `````````````````````````````````````````````````` ```````````````````````````````` On Mon, 16 May 2005 14:36:27 -0700, "Peter Duniho" wrote: "Robert M. Gary" wrote in message groups.com... [...] In the Mooney community is mostly agreed that a 201 (non turbo) will give you twice the cylinder life as a 231 (turbo). Other wear factors (heat, less air over the cylinders) are the same for turbo-norm vs. regular turbo. The only difference I can see is the "idiot" difference of accidently over boosting. Exactly what Mike said. Any kind of turbocharging will shorten the lifespan of a given engine. The whole point of a turbocharger, even turbo-normalizing, is to allow the engine to produce more power in certain situations than it otherwise would have. More power means more wear and tear. Turbo-normalizing isn't as hard on an engine as "non-normalized" turbocharging, but it still makes more power some of the time than the same engine without a turbocharger would (and on top of that, the increase in power is in situations when the air is less dense, making cooling more difficult...again, more heat, more wear). That time spent making more power results in more wear and tear. Pete |
Mike
Have you ever seen a flat 4/6 run hot at any altitude at 65% power? If your at 15K and engine is running 'hot' what do you do? Increase IAS, open cowel flaps or reduce power. My Mooney was as tightly coweled as anything I ever saw. On climb out after TO I used 120 mph to keep engine cool. It took longer to get to altitude but I made up for it by a long shallow descent at max IAS at destination. No shock cooling doing this. Block time was the same as Tech Order climb and dump for descent. When are you going to get out of that widow maker ![]() Big John `````````````````````````````````````````````````` `````````````` On Wed, 18 May 2005 19:22:04 GMT, "Mike Rapoport" wrote: The engine is going to be considerably hotter running at 65% at 15,000' than at 5,000'. Mike MU-2 "Big John" wrote in message .. . Peter Let me pose some what if's. I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. Big John `````````````````````````````````````````````````` ```````````````````````````````` On Mon, 16 May 2005 14:36:27 -0700, "Peter Duniho" wrote: "Robert M. Gary" wrote in message egroups.com... [...] In the Mooney community is mostly agreed that a 201 (non turbo) will give you twice the cylinder life as a 231 (turbo). Other wear factors (heat, less air over the cylinders) are the same for turbo-norm vs. regular turbo. The only difference I can see is the "idiot" difference of accidently over boosting. Exactly what Mike said. Any kind of turbocharging will shorten the lifespan of a given engine. The whole point of a turbocharger, even turbo-normalizing, is to allow the engine to produce more power in certain situations than it otherwise would have. More power means more wear and tear. Turbo-normalizing isn't as hard on an engine as "non-normalized" turbocharging, but it still makes more power some of the time than the same engine without a turbocharger would (and on top of that, the increase in power is in situations when the air is less dense, making cooling more difficult...again, more heat, more wear). That time spent making more power results in more wear and tear. Pete |
Hot is relative. It will certainly run *hotter*. Yes I have seen the
engine in a Turbo Lance (540S1AD) run hot at 19,000' at fairly low. An intercooler helps but it will still run hotter. One of the surprises with my Helio (GO480) is how low the CHT run (never seen over 375F) even though the rated HP per cu in is higher than the Turbo Lance. I hadn't flown a normaly aspirated piston except in primary training, so I just assumed that 400F was normal. Flying the MU-2 is as easy as flying anything else once you learn how. You just fly it by the numbers and everything will be OK. A lot of guys can't seem to do that and the training centers used to sign them off (they stopped when they lost a few lawsuits). The guys flying Barons that think that 3000' of runway is too short, or think that a Mooney is "slippery" have no business flying a MU-2 or any high performane airplane for that matter. It has to be flown like a swept wing jet. I haven't flown a great number of different airplanes so perhaps it is harder than average, I don't know. I may get rid of it soon because I just don't use it very much anymore. I hate to sell it because I feel totally secure and comfortable in it in all weather (most of my flying is IMC, over the mountains, in icing, often at night with very high winds. It is a perfect airplane for that kind of flying. The unfortunate reality is that now that I am only flying it ~125hrs/yr it is *costing* me a lot of *time* as well as money. The four day trip for recurrent training is only spread over 125total flight hrs and 20 of those hours are just to get to training and another 10 or so are to get somewhere for maitenance. The math works out to one hour of maitenance/training overhead for every productive flight hour which means the plane is effectively only half as fast. It has also pushed the cost/effective flight hour to well over $1000. I can see Roberts point about engine life being potentially reduced but I think that you are also getting a lot of advantages with turbocharging. Mike MU-2 "Big John" wrote in message ... Mike Have you ever seen a flat 4/6 run hot at any altitude at 65% power? If your at 15K and engine is running 'hot' what do you do? Increase IAS, open cowel flaps or reduce power. My Mooney was as tightly coweled as anything I ever saw. On climb out after TO I used 120 mph to keep engine cool. It took longer to get to altitude but I made up for it by a long shallow descent at max IAS at destination. No shock cooling doing this. Block time was the same as Tech Order climb and dump for descent. When are you going to get out of that widow maker ![]() Big John `````````````````````````````````````````````````` `````````````` On Wed, 18 May 2005 19:22:04 GMT, "Mike Rapoport" wrote: The engine is going to be considerably hotter running at 65% at 15,000' than at 5,000'. Mike MU-2 "Big John" wrote in message . .. Peter Let me pose some what if's. I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. Big John `````````````````````````````````````````````````` ```````````````````````````````` On Mon, 16 May 2005 14:36:27 -0700, "Peter Duniho" wrote: "Robert M. Gary" wrote in message legroups.com... [...] In the Mooney community is mostly agreed that a 201 (non turbo) will give you twice the cylinder life as a 231 (turbo). Other wear factors (heat, less air over the cylinders) are the same for turbo-norm vs. regular turbo. The only difference I can see is the "idiot" difference of accidently over boosting. Exactly what Mike said. Any kind of turbocharging will shorten the lifespan of a given engine. The whole point of a turbocharger, even turbo-normalizing, is to allow the engine to produce more power in certain situations than it otherwise would have. More power means more wear and tear. Turbo-normalizing isn't as hard on an engine as "non-normalized" turbocharging, but it still makes more power some of the time than the same engine without a turbocharger would (and on top of that, the increase in power is in situations when the air is less dense, making cooling more difficult...again, more heat, more wear). That time spent making more power results in more wear and tear. Pete |
In article et, Mike Rapoport wrote:
...get somewhere for maitenance. The math works out to one hour of maitenance/training overhead for every productive flight hour which means the plane is effectively only half as fast. It has also pushed the cost/effective flight hour to well over $1000. The thing is - is there an aircraft that WON'T have that overhead that will give you the reliability of the MU-2? Anything turbocharged/piston is likely to need more maintenance and just as much recurrent training. If it's not a high end pressurized turboed piston twin, you end up stooging around at low altitude like the rest of us and that kills your mostly all-weather capability. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() "Dylan Smith" wrote in message ... In article et, Mike Rapoport wrote: ...get somewhere for maitenance. The math works out to one hour of maitenance/training overhead for every productive flight hour which means the plane is effectively only half as fast. It has also pushed the cost/effective flight hour to well over $1000. The thing is - is there an aircraft that WON'T have that overhead that will give you the reliability of the MU-2? Anything turbocharged/piston is likely to need more maintenance and just as much recurrent training. If it's not a high end pressurized turboed piston twin, you end up stooging around at low altitude like the rest of us and that kills your mostly all-weather capability. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" Agreed, it is not a problem with the airplane, it is a problem with low utilization, need for specialized maitenance and trainig (neither availible locally).. I would not get another airplane to replace it, the plan is to charter. Mike MU-2 |
Big John wrote:
Peter Let me pose some what if's. I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. Possibly, because the air is much thinner at 15K than 5K and thus pulling the same power from the engine will cause it to run much hotter. Depending on how much hotter it runs, wear can be accelerated and you would certainly want to change your oil more often and run a semi-syn oil. Matt |
... [...] I have a turbo normalized engine. Going cross country I cruise at 5K and 65% power. Turbo is off. I then go on another XC and cruise at 15K and use turbo to pull 65%. Are you saying that cruising at 65% with turbo on will do more damage to engine than pulling 65% with turbo off?????? You'll have to define "more damage". Yes, as Mike said there are at least a couple of issues that cause the same power to result in hotter operating temperatures at higher altitudes than at lower. However, the increased temperatures may or may not result in damage, or even increased wear. There's just the *potential* for increase in wear. However, as far as I know, increased operating temperatures almost always translate into decreased lifetime. I'll agree that the turbo will require more maintenance it used but engine no if run within engine manufacturers specs. I'm having a hard time parsing that sentence. IMHO, the bottom line here is that no one ought to expect a turbocharged engine, turbonormalized or not, to require just as little maintenance as a normally aspirated engine. But that's not an indictment of turbocharging. It just means that with the significant benefit of turbo-charging, there comes a cost. As it happens, I feel that turbonormalization strikes a pretty good compromise. Even more so when the installation isn't strictly "normalization". Again, looking at my airplane as an example, the turbocharged installation has 20hp more than the normally-aspirated version. This isn't a lot of extra power, but it's enough to help compensate for the extra weight of the turbocharger and give a little extra "oomph", without significantly increasing the wear on the engine due to the power the engine is making. Yes, at altitude the engine runs hotter. It runs hotter than it would at the same power setting down low, and it certainly runs hotter than a normally-aspirated engine would at that altitude. But guess what? I go a lot faster too, to the tune of about 20 knots compared to what my best cruise speed at 8000' would be without a turbo. It's really nice being able to maintain cruise power up into the oxygen altitudes, and I get a nice true-airspeed boost as a result. As long as I'm not bucking a big headwind, it's all good. In addition, mountain flying is less dangerous. Ground speeds are still higher, and the prop can't convert the horsepower to quite as much thrust as it would at sea-level. But it's not nearly as much a reduction as I'd get without the turbocharger. Acceleration, even at max gross, is good as is the climb rate (handy when you are surrounded by high terrain ![]() What's the cost? Well, I can't speak for the average. But in my own case, I have had a "mini top overhaul" (replaced one piston, due to leaking rings on that piston, causing erosion of the piston head), and have had to replace all of the exhaust valves and guides. I don't even know that this was due to the turbo-charger, but certainly it seems that the extra heat may have accelerated the wear, if not caused it entirely. The turbo-charger itself has been remarkably maintenance free, especially considering it uses an automatic wastegate. As an added bonus, it acts as a muffler, so my airplane is somewhat quieter than similar-powered airplanes, and noticeably quieter than the normally-aspirated version. Since it's a seaplane, and since I do often operate in "well-habited" areas, this is a nice side-benefit. There is, of course, the acquisition cost too. Turbocharged airplanes seem to run anywhere from $20-50K more than the normally-aspirated equivalent. But given that airplanes are intentionally operated at above-sea-level altitudes on a regular basis, I can't imagine owning another airplane without turbocharging. Turbonormalized or otherwise. IMHO, it's much more important to look at the maintenance history for a given installation, than to try to paint all turbocharged aircraft with the same brush. The effects of turbocharging have as much to do with how the manufacturer recommends the engine is operated and the design of the installation (especially with respect to cooling), as they do with generalities about all turbochargers broadly. Pete |
![]() "Peter Duniho" wrote in message ... In addition, mountain flying is less dangerous. Ground speeds are still higher, and the prop can't convert the horsepower to quite as much thrust as it would at sea-level. But it's not nearly as much a reduction as I'd get without the turbocharger. Acceleration, even at max gross, is good as is the climb rate (handy when you are surrounded by high terrain ![]() Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Mike MU-2 |
"Mike Rapoport" wrote in message
ink.net... Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Really? I just assumed that with air density lower, the prop (CS or otherwise) had less air available to move, and thus could not produce sea-level thrust. I guess in that case, my longer take-off runs are solely due to the higher true speed required. Still, that's a significant effect. I just don't want anyone thinking that a turbocharger makes high-altitude takeoffs just like sea-level. Pete |
FS: Duo Discus Turbo - Texas, USA | Mark Zivley | Soaring | 2 | May 4th 05 11:34 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
Turbo prop AT-6/SNJ? | frank may | Military Aviation | 11 | September 5th 04 02:51 PM |
Turbo 182: correct mixture for final approach at high altitude? | Barry Klein | Piloting | 38 | January 15th 04 03:25 AM |
A36 Bonanza turbo prop | Jeff | Owning | 46 | January 7th 04 02:37 PM |
