![]() "Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message ink.net... Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Really? I just assumed that with air density lower, the prop (CS or otherwise) had less air available to move, and thus could not produce sea-level thrust. I guess in that case, my longer take-off runs are solely due to the higher true speed required. Still, that's a significant effect. I just don't want anyone thinking that a turbocharger makes high-altitude takeoffs just like sea-level. Pete The CS prop simply changes its angle of attack in response to the lower density.. Mike MU-2 |
![]() "Mike Rapoport" wrote in message ink.net... "Peter Duniho" wrote in message ... In addition, mountain flying is less dangerous. Ground speeds are still higher, and the prop can't convert the horsepower to quite as much thrust as it would at sea-level. But it's not nearly as much a reduction as I'd get without the turbocharger. Acceleration, even at max gross, is good as is the climb rate (handy when you are surrounded by high terrain ![]() Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Some of them. In the Bonanza conversions, you would need a new prop or else your engine is placarded to limit MP. Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
On Wed, 18 May 2005 17:33:58 -0700, "Peter Duniho"
wrote: What's the cost? Well, I can't speak for the average. But in my own case, I have had a "mini top overhaul" (replaced one piston, due to leaking rings on that piston, causing erosion of the piston head), and have had to replace all of the exhaust valves and guides. I don't even know that this was due to the turbo-charger, but certainly it seems that the extra heat may have accelerated the wear, if not caused it entirely. There was a website devoted to the wear of Lycoming valve guides that went into design and development of Lycoming engines, and also what they think is the actual problem causing the premature wear in certain models of Lycomings. You probably can find it by Googling "lycoming valve guide wear". To synopsize, the mechanics who took it upon themselves to research the problem feel that it is Lycoming's use of a particular type of cam follower or lifter, that has created the situation (of accelerated valve guide wear). Lycoming patterned their original lifter after those used by flathead engines. Since flathead engines have the valves in the block, not the head, the lifter design, which was not intended to flow much oil through it, worked fine. But when this lifter was used in Lycoming's overhead designs, there were problems because not much oil was getting to the valve guides and they suffered premature wear. Many of the fixes for those engines that suffered the most are fixes that bring more oil to the valve guide area, according to this well documented and extensive three or four part article. But the conclusion of the article is that Lycoming does not have the in-house engineers to come up with a real fix at this point. Corky Scott |
FS: Duo Discus Turbo - Texas, USA | Mark Zivley | Soaring | 2 | May 4th 05 11:34 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
Turbo prop AT-6/SNJ? | frank may | Military Aviation | 11 | September 5th 04 02:51 PM |
Turbo 182: correct mixture for final approach at high altitude? | Barry Klein | Piloting | 38 | January 15th 04 03:25 AM |
A36 Bonanza turbo prop | Jeff | Owning | 46 | January 7th 04 02:37 PM |
