Hi, Nyal, hope I can shed some light... I use a Volkslogger and find it
has a pretty interesting learning curve. Nyal Williams wrote: My partner and I are tripping over each other in using the VL. We upload our tasks and waypoints from SeeYou and want to download recorded flights for official purposes. So you use a PC or PC laptop, using SeeYou, to upload each day, or multiple flights in a day? And then use the official VL programs DATA-GCS.EXE and VALI-GCS.EXE that come with the VL to read IGC files? VL claims it can store 25 pilots and 500 turnpoints. Our questions are these: 1. How do we erase tasks and turnpoints from VL to keep it simple and uncluttered? I have to ask, if there are still tasks/turnpoints, what is the problem? AND, I would rather have the set of turnpoints available. At least for our area, most turnpoints are airports and most airports are landable. When you press EMR on the VL the five nearest are available for navigation. It can be a comforting feature. Regardless, to "erase", create a database (task and turnpoint) of two points, one task. Whenever the two turnpoints and task are uploaded to the VL, the rest are overwritten. Overwriting of the pilot list and other info will not occur, in my experience. 2. (This might be a SeeYou question) How do I upload a single task from SeeYou? ( I believe that all tasks I have worked out in SeeYou get uploaded at once.) In SeeYou, Save As, your task's name, and then the dialog box with " " comes up. Click the " " to put all tasks/turnpoints to the left (on the PC), then highlight the single task and click " " to put it to the save side. Save it. The pilot name, ship, etc. is not part of the task and is not saved with the task. Then open your task's name. You can edit your declaration, pilot information, etc. at this time. Now upload it all to the VL. 3. If tasks and/or turnpoints remain in VL and it is impossible to erase, how can I be sure I have identified the correct task for declaration? When you create tasks in SeeYou, name them. Highlight a task, right click on Properties, and change the name there. According to the VL manual, you can use 14 characters, so you could use for example: "NYAL_500K1_CCW" to remember it is your task, a 500K, #1, in the counterclockwise direction. Or 3 turnpoint names, or whatever code system you want. When you turn on the VL, go to the menu. You will skip NAV, skip INF, select FAI, skip INFO (for now), select TASK, select Copy RTE from DB?, and scroll through to find "NYAL_500K1_CCW". (See www.winpilot.com, click gliders, click compatable hardware, click VL for a great pictorial representation of the VL menu system.) Then, (sorry), check the task. This step is needed if you are using the VL to beep at you when you correctly enter each observation zone. If you just are recording the flight, and relying on some other system to navigate to your points, you don't need to verify. To verify, check start, each turnpoint, finish. Check the observation sectors when you check each point including start and finish. (There may be a SeeYou problem, I know SeeYou isn't creating start lines for tasks I have created. I have to go in and fix that after FAI/TASK/Copy.) Then (everyone) go back and check the pilot info, ship, etc. Then declare and you are ready to go. 4. If erasure is not possible, how can I and my partner coordinate our separate files to be sure we are not choosing the wrong task or crediting the wrong pilot with the task flown? (Naming or numbering tasks can become complicated without close coordination; I can't imagine 25 pilots in a club managing one of these loggers) See above. Nyal, you get all the tasks starting with "N". Upload and verify. Any comments would be appreciated; I have not been able to reach a dealer who can assist me. Do try this at home! Much better than being ****ed off at 6k' under beautiful cu's! John Gilbert |
