![]() "Robert M. Gary" wrote in message oups.com... That is my point. There does not appear to be any reason for anyone to ever buy a turbo norm system. The engine runs just as hot/hard, etc at altitude with a turbo norm vs. a regular turbo. The turbo norm companies try to trick people into thinking that putting a turbo norm on your engine will not wear your engine any more than normal asp because you never get over 30". However, the argument appears to be worthless, in truth a turbo norm wears out your engine just as fast as a regular turbo. -Robert I would disagree, there are a lot of reasons to buy a turbo (nomalizer or otherwise). To fly higher, fly faster, climb much faster, takeoff shorter (much shorter at high DA). Mike MU-2 |
![]() Mike Rapoport wrote: I would disagree, there are a lot of reasons to buy a turbo (nomalizer or otherwise). To fly higher, fly faster, climb much faster, takeoff shorter (much shorter at high DA). You also have to look at your options. I will be putting the Pponk engine into my 182 next fall. It is 275 HP. My airplane will outperform the Turbo 182's until the density altitude reduces my 275 HP to less than the 230 HP of the turbo engine. And since I am buying it for takeoff and climb performance and not cruise speed I will always outperform the turbo because my typical mountain flying mission always allows me to have more than 230 HP available. The breakeven point is 84% power. |
![]() "Newps" wrote in message ... Mike Rapoport wrote: I would disagree, there are a lot of reasons to buy a turbo (nomalizer or otherwise). To fly higher, fly faster, climb much faster, takeoff shorter (much shorter at high DA). You also have to look at your options. I will be putting the Pponk engine into my 182 next fall. It is 275 HP. My airplane will outperform the Turbo 182's until the density altitude reduces my 275 HP to less than the 230 HP of the turbo engine. And since I am buying it for takeoff and climb performance and not cruise speed I will always outperform the turbo because my typical mountain flying mission always allows me to have more than 230 HP available. The breakeven point is 84% power. Agreed. The ultimate for the Helio is the 450hp Allison engine. Although it is a turbine and therefore loses power with altitude like a normally aspirated piston, it still have more power than a turbo normalized recip and is significantly lighter as well. I am somewhat surprised that you always have 84% power availible for takeoff in the mountains. Mike MU-2 |
![]() Mike Rapoport wrote: I am somewhat surprised that you always have 84% power availible for takeoff in the mountains. I don't of course. That's the breakeven point with the turbo. |
![]() "Mike Rapoport" wrote in message news:hyTie.4294 I would disagree, there are a lot of reasons to buy a turbo (nomalizer or otherwise). To fly higher, fly faster, climb much faster, takeoff shorter (much shorter at high DA). In the case of the B36TC, your TBO goes up 100 hours. Here is some data and examples (Check the brochure links at the bottom of the page). http://www.taturbo.com/tcppr.html Here is the contrast from a TSIO-520 to a TNIO-550 http://www.taturbo.com/performance.html Reference http://www.taturbo.com/houtbk.jpg Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
FS: Duo Discus Turbo - Texas, USA | Mark Zivley | Soaring | 2 | May 4th 05 11:34 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
Turbo prop AT-6/SNJ? | frank may | Military Aviation | 11 | September 5th 04 02:51 PM |
Turbo 182: correct mixture for final approach at high altitude? | Barry Klein | Piloting | 38 | January 15th 04 03:25 AM |
A36 Bonanza turbo prop | Jeff | Owning | 46 | January 7th 04 02:37 PM |
