Jay Honeck wrote:
We have a Narco CP-136 audio panel, and a PS Engineering CD/Intercom. I'm assuming the input jack has to "patch in" to the intercom somewhere. (Frustratingly, a jack already exists for the back-seat passengers only. It's a nice feature so that they can listen to their own music in back -- but we don't have the same option in the front seats.) Yes, the usual place to wire in an audio input is into the intercom harness. You need a schematic of the wiring plug pins -- this usually is part of the owner's manual for the intercom. The better intercoms have two sets of audio inputs; one for the front two seats and the other for everybody else. Sounds like the original installer didn't hook up the front set in your plane. I think you should be hunting for a manual. I would contact PSE and see if I could get a replacement manual. If you're determined to take it to a shop, I'd guess it'll be about 2 hours work. Maybe a bit less. If the harness is tight and the plug hard to get to, it could well be more. George Patterson "Naked" means you ain't got no clothes on; "nekkid" means you ain't got no clothes on - and are up to somethin'. |
hours work. Maybe a bit less. If the harness is tight and the plug hard to get to, it could well be more. Thanks, George. It sounds easy enough. (Oh, man, I've gotten into the biggest trouble with those four words! :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
avionics book reference and question | mah | Military Aviation | 14 | October 5th 03 01:17 AM |
