Logging Right Seat Time
Old May 22nd 05, 01:54 AM
Ron Natalie
Jose wrote:
I'm a Captain in all the planes but move to the right seat often. When
I'm in the right seat what can I log?
IMHO, If you are the Pilot In Command, you log PIC time, no matter what
(physical) seat you sit in.
Where you sit is not important. However, the rules don't say "LOG PIC
TIME WHEN YOU ARE PIC." In order to do that there are additional
qualifications. The most commonly used one is that the regulations
(lets say Part 135) require more than one pilot.
My strict reading of 61.51(e) says that if you are not the "sole
manipulator", then even if you =are= the PIC, then so long as anybody
else is handling the controls, you can't log PIC time,Y
You better read 61.51 again. There are three more clauses than the
one you're reading.
Old May 22nd 05, 02:32 AM
Jose
My strict reading of 61.51(e) says that if you are not the "sole manipulator", then even if you =are= the PIC, then so long as anybody else is handling the controls, you can't log PIC time,Y
one you're reading.
I didn't think they were relevant to the discussion.
Rec, private, or comm pilot may log PIC if...
sole manipulator (& rated) ... or sole occupant ... or (not except for
rec pilots) =is= PIC when two pilots are required.
The other clauses pertain to ATPs, authorized instructors, and student
pilots. So I was focusing on the first set.
We were discussing a situation where only one pilot is required, and
there is another occupant of the aircraft. In this case, I believe that
as I wrote above, a strict reading says that even if you =are= the
actual Pilot In Command (perhaps by dint of being the only pilot aboard,
perhaps by another dint), then if anybody else is handling the controls,
you can't log PIC time. However, if an FAA approved robot is handling
the controls, then you can.
Handling the robot (turning on the autopilot) apparantly counts as
handling a control. You can program the FMS to do the takeoff, cruise,
and landing, take a nap, and set an alarm for when your wheels touch the
ground again, and log the whole thing as PIC. You can do this with a
non-FAA approved robot too, if you are flying an experimental class
aircraft. (At least I think that's true - how much does the FAA get
involved in certification of instrumentation and such for
experimentals?) It's unclear as to whether you can let a monkey operate
the controls and still log it as PIC (which may be a problem for those
that employ the cat-dog-duck method of IFR flight), but if you let a
human act as your autopilot, a strict reading of the rules says nix on
the logbook.
So, you (a regular private pilot) go up in a 172 with a friend who is
not a pilot, you let him take the controls while you very carefully
supervise her, and you can't log the time PIC. The next day you fly a
Cirrus by programming the CID (Cirrus Autoflight Device) and pushing the
GO button, essentially become a passenger while the glass cockpit does
the work, and all that time goes in your book as PIC.
Doesn't make sense to me. This is why I mention the organic autopilot.
Jose
I used to make money in the stock market, now I make money in the basement.
Old May 22nd 05, 03:07 AM
Mike Rapoport
"Jose" wrote in message
news
one you're reading.
sole manipulator (& rated) ... or sole occupant ... or (not except for rec
We were discussing a situation where only one pilot is required, and there
is another occupant of the aircraft. In this case, I believe that as I
wrote above, a strict reading says that even if you =are= the actual Pilot
In Command (perhaps by dint of being the only pilot aboard, perhaps by
another dint), then if anybody else is handling the controls, you can't
log PIC time. However, if an FAA approved robot is handling the controls,
then you can.
involved in certification of instrumentation and such for experimentals?)
It's unclear as to whether you can let a monkey operate the controls and
still log it as PIC (which may be a problem for those that employ the
cat-dog-duck method of IFR flight), but if you let a human act as your
autopilot, a strict reading of the rules says nix on the logbook.
So, you (a regular private pilot) go up in a 172 with a friend who is not
a pilot, you let him take the controls while you very carefully supervise
her, and you can't log the time PIC. The next day you fly a Cirrus by
programming the CID (Cirrus Autoflight Device) and pushing the GO button,
essentially become a passenger while the glass cockpit does the work, and
Jose
basement.
I think that it is simpler. You can log pilot time when the FAA requires
you to be in the airplane performing as pilot. If you are not required (ie
you are one of 4 pilots in a 172) you can't log the time.
If you go through the specific rules this seems to hold true. Every time
that there is an instance where two pilots can log time, it is becasue two
pilots are required by regulation.
Mike
MU-2
Old May 22nd 05, 03:28 AM
Gary Drescher
news
That's correct, at least according to the wording of the FARs (61.51e).
Whether it's what the FAA really intended is anyone's guess.
handling a control.
Yup. Whereas a passenger does not count as a control. That distinction per
se (between what is and isn't a control) is reasonable, though the
corresponding distinction between the time you can and can't log is less
reasonable, as you point out.
--Gary
Old May 22nd 05, 05:11 AM
Jose
handling a control.
Why?
This is a serious question, especially considering the capabilities of
some robots, and the lack of capability of some organic autopilots.
Jose
Old May 22nd 05, 12:46 PM
Gary Drescher
news
handling a control.
per se (between what is and isn't a control) is reasonable
Why?
The distinction is reasonable because the ordinary meaning of 'control' is
that it refers to an inanimate or non-sentient device, not to a person. As
sophisticated as some autopilots are, they are not yet sentient. You're
right that *for purposes of logging PIC time*, that distinction doesn't
matter (though for many *other* purposes it certainly matters!). So the line
drawn by 61.51e doesn't make much sense, but that's different from the
distinction between control and non-control not making sense. The FAA should
just rephrase 61.51e(ii) to say "sole rated occupant" rather than "sole
occupant".
--Gary
Old May 22nd 05, 06:18 PM
Newps
handling a control.
Why?
It's a distinction without a difference. Nobody with more than three
brain cells left who goes flying for an hour and lets their 10 year old
kid fly for 30 minutes of that hour only logs 30 minutes as PIC.
Old May 22nd 05, 06:26 PM
Gary Drescher
"Newps" wrote in message
Nobody with more than three brain cells left who goes flying for an hour
and lets their 10 year old kid fly for 30 minutes of that hour only logs
30 minutes as PIC.
Why? Even if you're convinced that the FAA didn't mean what it said when it
wrote 61.51e (which is quite possible), what would be the harm in playing it
safe and logging no more time than the FARs actually say you can log?
--Gary
Old May 22nd 05, 11:05 PM
Jose
Nobody with more than three brain cells left who goes flying for an hour and lets their 10 year old kid fly for 30 minutes of that hour only logs 30 minutes as PIC.
Well that leaves me out. I have three functioning brain cells, of which
only two operate at the same time.
How many rat cells is the new organic autopilot made from?
Jose
The price of freedom is... well... freedom.
Old May 22nd 05, 11:55 PM
Ron Natalie
This is where I usually make some crack about the sole manipulator of
the pilot in command.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Cross Country Logging time Jim Piloting 14 April 21st 04 09:58 PM
Logging time as safety pilot? CFLav8r Piloting 26 February 7th 04 11:35 PM
Where are the CFIG's? Michael Soaring 10 August 19th 03 12:23 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
