Spruce
Old May 22nd 05, 11:51 PM
jerry wass
Ron Wanttaja wrote:
On 21 Apr 2005 23:52:07 GMT, "Caveat Empty Headed." wrote:
I've located a source of spruce in British Columbia that appears to be very
good. http://www.timberwright.ca/aircraft.html
anyone dealt with them?
One of our Fly Baby list folks visited them last summer, and was very pleased.
You should be able to access his posting at:
http://groups.yahoo.com/group/flybabylist/message/4034
One LEETLE thing !! Order your boards the approximate width of their
final use size---i.e. final size + 1/2 " or so for final STRAIGHTENING
AND TRIMMING. I had some beautiful edge grain Doug Fir Kiln Dried, that
had aged in storage for some time nice and flat and straight.. --
I ripped a 1X6 down the middle and had two pieces with about a 1" bow
toward the middle, you could see it opening up as you sawed it--14 Ft.
long. This board had a slight change in the # of growth rings across
the board...must have set up a stress due to the difference in density
across---was probably a small--(relatively} tree.
to get my 4-1/2" spars out of a 5-1/2" board, I sawed about 3/16" off
each side --checked for straightness, let it set a day or two & repeated
the process till I got down to planing & checking after each run
through the planer..
DON'T TAKE IT ALL OFF ONE SIDE AT ONCE !!---Jerry
Old May 23rd 05, 02:30 AM
Lou
If your going to go through this much trouble (just a choice of words),
you might want to consider ordering your lumber rough sawn. Although I
used Doug Fir, I ordered my materials rough sawn and was able to mill
twice as many of the smaller parts from a 1" rough sawn board than 3/4"
planed material. It really keeps the cost down. On the down side, you
will have to invest in a cheap planer.
Lou
What Others Are Saying About Aircraft Spruce jls Home Built 29 February 18th 05 11:29 PM
Aircraft Spruce: Abused Customers and Fourteen More Angry Comments -- More to Come jls Home Built 2 February 6th 05 08:32 AM
Buying Junk from Aircraft Spruce --- Or Putting Money Down a Rathole jls Home Built 41 February 5th 05 08:04 AM
Complaints about Churchgoer Jim Irwin and Aircraft Spruce --- Just the Tip of the Iceberg--- They Go On and On and On jls Home Built 6 February 4th 05 07:07 AM
sitka spruce al pernell Home Built 43 February 25th 04 11:02 PM
