C172 crash at Coney Island
Old May 23rd 05, 01:32 PM
OtisWinslow
Full gross. Tight turn with sightseers. I doubt a "stalled" engine
had much play in this one. You have to maintain enough airspeed
for the wing to keep flying. Very sad deal innocent people had
to die.
"Gary Drescher" wrote in message
"Ernest C. Evans" wrote in message
I'm not a pilot but I was wondering why this plane went down "nose first"
??? I'm thinkin', don't these things have some gliding ability ???
i guess the pilot must've been too low to recover ..... Having an engine
quit on you is bad enough luck ..... but having it happened when you just
happen to be at a low altitude is even worse luck ! (
Actually, having an engine quit would *not* cause a plane to fall. As you
say, it would just glide instead.
What does cause a plane to fall--whether the engine is running or not--is
pulling back too far on the control wheel, which causes the plane to slow
down too much (at least, that's the simplified explanation). When that
happens, witnesses who are not familiar with aerodynamic principles often
perceive the incident as an engine failure, which is then how the press
reports it initially.
You're right too that when a plane stops flying (the technical term is
"stalling", but that's confusing because it has nothing to do with the
*engine* stalling), you can recover if you have enough altitude, but being
lower makes recovery harder. Stall recovery shouldn't take much more than
100 feet, but there's a particularly bad type of stall--called a
spin--that can take more than 1000 feet to recover from.
--Gary
C172 Plane crash Orlando, FL CFLav8r Piloting 25 January 15th 05 08:54 PM
Long Island Crash - Kite String? Neb Okla Rotorcraft 5 September 3rd 04 05:43 PM
Navy releases names of 4 killed in island crash Otis Willie Military Aviation 0 August 14th 04 11:21 PM
Madeline Island and Richard I. Bong Museum PIREP Jay Honeck Piloting 3 July 20th 04 03:21 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
