I also meant to add that since the multi-tasking is the hard part, I'm
not convinced that the style of cockpit, whether glass or steam, really matters that much. The critical issue is how much time the pilot has to devote to setting up the approach. |
![]() "Paul kgyy" wrote in message oups.com... I also meant to add that since the multi-tasking is the hard part, I'm not convinced that the style of cockpit, whether glass or steam, really matters that much. The critical issue is how much time the pilot has to devote to setting up the approach. You have not flown with a glass cockpit are advanced steam guages have you? Both make the flying part easier and require less of a scan which allow more time/bandwidth for futzing with avionics or charts. In my airplane the ADI has a flight director and also displays localizer and glideslope information, you only need to glance at it and you see the whole flying/navigation picture. Glass panels are even easier. Mike MU-2 |
Paul,
After flying and instructing in both types of cockpits, my experience is that the "glass' version is far easier to use, cuts workload dramatically and, in my opinion, makes instrument flying much easier. It allows information to be obtained and processed faster and helps one's situational awareness significantly, allowing the pilot to stay well ahead of the airplane, even as the workload goes up in a terminal area. All of that recognizes that there is a learning curve to the glass cockpit, but the presentation is so intuitive, that one catches on quickly. All the best, Rick |
Turbine air start -- too cold? | Juan Jimenez | Home Built | 97 | March 14th 05 06:51 PM |
Turbine air start -- too cold? | Juan Jimenez | General Aviation | 54 | February 2nd 05 04:14 AM |
Start receiving MONEY with this simple system. Guaranteed. | Mr Anderson | Aviation Marketplace | 0 | February 2nd 04 11:55 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Start Anywhere Cylinder (SSA rules proposal) | Mark Navarre | Soaring | 15 | September 25th 03 01:13 PM |
