Anyone try paragliding?
Old May 24th 05, 10:06 AM
Antoņio
The paraglider is not the same machine as a parachute, as you have
noticed. It has a higher aspect ratio (width to length ratio, for you
non-pilots) which gives it a greater glide ratio. Greater glide ratio
equates to greater instability in a paraglider. Instablility, in this
case, is the tendency of the paraglider to collapse under, for example,
the varying the front-to-back air pressures of thermal activity.
Paragliders are not designed to take terminal deployment -- that is, a
full-fall deployment. They are made of lighter materials in the sail
and lines. They can come apart at terminal velocities.
Paragliders have more cells to inflate and are not nearly as stable as
parachutes.
Once inflated, parachutes tend to stay inflated while paragliders do
not. Any small end-cell deflation in a paraglider can cause a
spiraling down condition. Unless the pilot is on the ball and shifts
pressures to the deflated side the spiral develops to a point where it
is unrecoverable. This happens in matter of seconds.
Finally, the shape and condition of the paraglider is critical. This
shape changes over time as the material wears and the lines stretch or
the fabric becomes more porous. The flight characteristics of a worn
paraglider can make it positively dangerous regardless of the
conditions.
Antonio
Old May 24th 05, 10:08 PM
John Galban
noticed.
snip
Thanks for the thorough explanation. I appreciate it!
John Galban=3D=3D=3D=3D=3DN4BQ (PA28-180)
Cheap sailplanes tango4 Soaring 100 December 21st 04 08:21 PM
new pictures in Paragliding Gallery jaro Soaring 0 July 8th 04 11:30 PM
www with paragliding adds Mariusz Klos Aviation Marketplace 0 April 22nd 04 11:53 AM
New Paragliding Gallery jaro Soaring 0 December 28th 03 08:51 PM
Red Bull Vertigo 2003 Red Bull Vertigo Aerobatics 2 August 11th 03 08:02 PM
Copyright Đ2004-2025 AviationBanter.
