Weigh scales
Old May 24th 05, 12:30 AM
abripl
Default Weigh scales
I sold my mechanical Ruggles weigh scales and now am trying some
digital automotive racing scales that are just a little more expensive.
The scales I found are actually less expensive than normal racing
scales but the real advantage is that they can be sold individually
rather than a set of four. For my purposes I only need two (use
bathroom scale on front wheel) and that brings the price down to about
$500 for two digital scales compared to $310 for the
mechanical Ruggles scale set. I tested the accuracy of the new digital
scales and they seem to be accurate to the nearest pound thats quite
better than Ruggles. You can see the scales at
http://racing.centralcarolinascale.com/low-cost.htm
Another place
http://www.usedscales.com/ws_and_ps_race_car_scale.htm
also sells them, but when they found out I was going to use them for
aircraft, they went bezerk and would not sell them to me but insisted
that I purchase more expensive ones. I tried to explain that I can
possibly calibrate the cheaper ones (just like you calibrate a compass
with a compass correction chart) but they were so caught up in
superlatives and safety slogans they would not listen.
Any two of you can get together and purchase a whole set for about $900
and split it. Thats only about $450 for digital aircraft scale set
(plus one good bathroom scale).
Old May 24th 05, 02:14 AM
Rich S.
"abripl" wrote in message
Or . . . you can find a pal who works for the gummint,
who knows a pal in the motor pool,
and borrow a set of portable truck scales.
Your taxes at work!
Rich S.
Old May 24th 05, 03:36 AM
Orval Fairbairn
In article .com,
Another place
One caveat on using scales:
Make sure that the hangar doors are closed, so there are no stray
breezes to interfere with the weighing. Stray breezes can cause as much
as 10-15 lb weight errors per scale.
A good test is to weigh the plane, then remove it from the scales and
heck the "zero weight" indication.
Remove _'s from email address to talk to me.
Old May 24th 05, 01:33 PM
OtisWinslow
You might try some of the gokart racing suppliers too. They use digital
scale systems for setup.
Another place
Old May 24th 05, 03:13 PM
abripl
digital
The problem with go cart scales is their capacity limited to 500lb
maximum each and their platforms are smaller/awkward. My main wheels
are about 700lbs each.
Unless you are talkin only ultralights.
Glider weighing scales C AnthMin Soaring 0 July 12th 04 06:53 AM
Glider weighing scales. Terence Beasley Soaring 2 July 7th 04 04:14 AM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Aircraft Scales Kyle Boatright Home Built 6 June 19th 04 07:59 PM
AVIATIONTOOLBOX: GeoTIFF chunks of conUS in several scales Kyler Laird General Aviation 0 January 4th 04 05:12 PM
